58 Savoy rear end exchange?? #914277
01/26/11 09:44 AM
01/26/11 09:44 AM
Stoney Creek, Ontario, Canada
76Beeper Offline OP
76Beeper  Offline OP
My buddy has a 58 Savoy and wants to put a newer style 8 3/4 rear in it. Which 8 3/4 will fit without too much modification?
Re: 58 Savoy rear end exchange?? [Re: 76Beeper] #914278
01/26/11 10:30 AM
01/26/11 10:30 AM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
E- body fits perfectly except the perches will have the pinion too high, cut and reweld perches and your there
Re: 58 Savoy rear end exchange?? [Re: 76Beeper] #914279
01/26/11 08:16 PM
01/26/11 08:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The C and E body both share the '58 spring pad width, overall width varies but both are wider than the '58.
Re: 58 Savoy rear end exchange?? [Re: John_Kunkel] #914280
01/26/11 11:07 PM
01/26/11 11:07 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
FWIW I have 15X8-4.5bs w/275/60/15's dead center in the wheelwells of my 58 Suburban
Re: 58 Savoy rear end exchange?? [Re: John_Kunkel] #914281
01/27/11 06:16 PM
01/27/11 06:16 PM
Ontario, CANADA
hemi pwr Offline
hemi pwr  Offline
Ontario, CANADA
Do you think a 69 b body would be perfect because its not as wide as the e body????? Do you know what backing platte to backing plate width is????
1970 440-6 Cuda 71 duster 1999 Dodge ram diesel dually 1958 plymouth hardtop 1975 Fury 2 door 1970 AAR cuda clone
Re: 58 Savoy rear end exchange?? [Re: hemi pwr] #914282
01/27/11 10:15 PM
01/27/11 10:15 PM
PA
W
Waynes48 Offline
Waynes48  Offline
W
PA
I'm not sure this will help you, but I'm installing an 8 3/4" 1968 Roadrunner rear housing in my 1948 Plymouth. I measured approximately
55 3/16" from the flange outer mounting surface to flange outer mounting surface, with no brake backing plates in place yet. Spring perch placement for my vehicle required 46 1/2" center to center distance. I believe that the 1969 B-body used the same rear housing. Hope this helps you out.
Additionally, I was informed by the machine shop assembling the rear, that the center section (not from a Roadrunner) had some serious wear issues (741 case, open type). Needed new cross shafts, spider gears, side gears. Seems that those parts are no longer available, so I was kinda forced to replace the internals with a True Trac Posi unit. Spent nearly $1000 total for the housing, center section, carrier bearings, Green axle bearings, seals, labor, and all new brake parts, bead blasting old drums and having them turned, etc. I might have been better off finding an alternative, but had too much invested to change directions at that point. Just be forewarned that your investment in the 8 3/4" unit might be considerable.
Re: 58 Savoy rear end exchange?? [Re: Waynes48] #914283
01/27/11 11:47 PM
01/27/11 11:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The Standard Catalog of Chrysler 1924-1990 list the front wheel tread of all models as 60-29/32 and the rear tread for all models as 59-39/64. One would presume that to mean the width of the wheel mounting surface.
My old Direct Connection book lists the standard track width by body style. 8-3/4
A body, 67-72 as 55.56 Spring seat center to center 43.2
B body 62-70 as 59.2 spring seat c-c 44.0
E body 70-74 as 60.7 spring seat c-c 46.0
B body 71-74 as 62.0 spring seat c-c 47.3
B body S.W. 71-74 63.4 spring seat c-c 47.3
Also lists 9-1/4
B body at 62.0 spring seat c-c 47.3
and a B & C body at 63.4 spring seat c-c 47.3
and an F body 8-1/4 as 58.50 spring seat c-c 44.46
Have fun. Gene
Re: 58 Savoy rear end exchange?? [Re: hemi pwr] #914284
01/28/11 05:44 PM
01/28/11 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The correct dimensions are in the tech archives:
http://www.moparts.org/Tech/Archive/axle/16.html
The '64 B body has the same dimensions as the '58 with the exception of the spring pad width which is 46" on the '58.
Re: 58 Savoy rear end exchange?? [Re: John_Kunkel] #914285
01/29/11 01:58 PM
01/29/11 01:58 PM
76Beeper Offline OP
76Beeper  Offline OP
Many thanks to everyone that replied
Alot of good information here.....
My buddy (Lil-hemi) has somethin to work with.
Re: 58 Savoy rear end exchange?? [Re: 76Beeper] #914286
01/31/11 09:34 PM
01/31/11 09:34 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Just a couple of those for what it's worth things.
If your friend is wanting to upgrade primarly becasue of the brakes and tapered axels AAJ makes a rear disc brake conversion for these axels that may be an alternative to swapping the whole rear end.
I ended up with a couple of 9 1/4" rears out of 77-8 full size Chryslers some years ago both with 3.21 Sure grips. I paid less than $100 each for them because nobody else wanted them. They are 1 1/2" wider than the stock rear ends on the 57-8 Dodge and Plymouths (3/4" per side). The spring perches had to be relocated but that is pretty minor. One ended up under a 57 Coronet I had and the other is under my 57 Plymouth.
As it happened I built 76 Dodge D100 a couple of years ago and in the process discovered the mid 70s dodge pickups used the exact same axel with the exception that the truck spring perches are located on top of the axel (which would need to be changed anyway). I bring this up as the pickup 9 1/4 are also more likely to have a bit deeper gear set (3.50) and possibly a SG. Thought I'd throw that out as an alternative in case your buddy is interested.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 58 Savoy rear end exchange?? [Re: Mike P] #914287
02/11/11 09:31 AM
02/11/11 09:31 AM
76Beeper Offline OP
76Beeper  Offline OP
Thanks for that info Mike.....
