29x9x15 what rim size ? #914239
01/26/11 02:04 AM
01/26/11 02:04 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Budget build....anyone ever run a 29x9x15 slick on a stock steel rim ? Rim says 15x7 from a 70's Dodge van,but measuring inside lip to inside lip measures 6.5 inches.
I know 15x8-15x10 is optimum,just would like real world experiences.
going on 69 big block,4-speed
Re: 29x9x15 what rim size ? [Re: jcastle1] #914240
01/26/11 02:10 AM
01/26/11 02:10 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
How does the tire measure just sitting? Real flexible side-wall ? I would think a 6.5 rim would be fine.
Re: 29x9x15 what rim size ? [Re: jcastle1] #914241
01/26/11 03:07 AM
01/26/11 03:07 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You really need at least an 8" rim to allow for running sufficient pressure to keep the tire stable on the big end. Otherwise, you'll be running a lower pressure to get a decent "footprint" that will get loose at high speed.
Re: 29x9x15 what rim size ? [Re: jcastle1] #914242
01/26/11 03:53 AM
01/26/11 03:53 AM
Cab_Burge Online work
Cab_Burge  Online Work
You have a PM
Re: 29x9x15 what rim size ? [Re: jcastle1] #914243
01/26/11 11:04 AM
01/26/11 11:04 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
9" minimum, 10" preferred. I wouldn't even consider 7".
Re: 29x9x15 what rim size ? [Re: jcastle1] #914244
01/26/11 01:36 PM
01/26/11 01:36 PM
North Texas
1AARCUDA Offline
1AARCUDA  Offline
North Texas
Ive run them on 8 1/2 Centerline Auto Drags! Going on my third season, never a problem!
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: 29x9x15 what rim size ? [Re: 1AARCUDA] #914245
01/26/11 01:50 PM
01/26/11 01:50 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
if you want to stick with stock style check out wheel vintiques at summit.
I got a pair of 15x10 cop wheels to go with my 15x7 on the front. There heavy but I like the way they look.
They have lots of oe reproductions in different widths
Re: 29x9x15 what rim size ? [Re: sturmenater] #914246
01/26/11 09:56 PM
01/26/11 09:56 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Thanks for the help!Guess I'm gonna look for some wider rims.
John
Re: 29x9x15 what rim size ? [Re: jcastle1] #914247
01/26/11 11:48 PM
01/26/11 11:48 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I use 8" rims with a 9" tire. I also have a set of tires that have on the sidewall 28x11.5 but they are only 8.8" wide.
Re: 29x9x15 what rim size ? [Re: jcastle1] #914248
01/29/11 04:02 PM
01/29/11 04:02 PM
John
You have a PM
Re: 29x9x15 what rim size ? [Re: jcastle1] #914249
01/29/11 05:53 PM
01/29/11 05:53 PM
TMP66 Offline
TMP66  Offline
Your key words are "budget build". A 7" steel wheel will work just fine on a 9x29 tire.
If there are any mid to late 80's 5th avenues in yards in your area, they had 15x7 wheels.
Re: 29x9x15 what rim size ? [Re: TMP66] #914250
01/29/11 07:35 PM
01/29/11 07:35 PM
K
KOS Offline
KOS  Offline
K
i ran that exact tire on a 7"rim for years going as fast as 9.7s in a stock suspension dart.
Re: 29x9x15 what rim size ? [Re: KOS] #914251
02/01/11 01:13 AM
02/01/11 01:13 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
The rims I have,I thought were 7".Inside lips measure 6.5"Rim is stamped 15x6.5"I think from listening to these posts I'm gonna order some cheapie Wheel Vintiques 15x8 (4.5 backspacing)from Summit and call it a day!
I'm very green when it comes to racing,or even t&t @ the track. I don't want the car to feel too squirrely @ the end.
Only bad thing is,I already had 4 of these rims (15x6.5) in perfect condition,no bends or warping,sandblasted,painted black & ready to go!
Thanks for all the replies!
John
