Re: Font and vin number of engine block, is it correct? [Re: blewbyu] #914165
01/28/11 04:29 AM
01/28/11 04:29 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I seen the other post and was just pulling your chain since your looking for work in some posts. Sorry if it was taken wrong...What I was getting at is it seems some of the nicer dusters are pulling more then some of the early 70s e bodies...
Hey if people are now making fake F-body fender tags, they will restamp a 5k duster, not to imply this was.
Re: Font and vin number of engine block, is it correct? [Re: ScottSmith_Harms] #914166
01/28/11 01:37 PM
01/28/11 01:37 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
My trans has the goofy multiple-, angled-, light-strike stamp. No picture handy, it is comforting to know I'm not alone...
Re: Font and vin number of engine block, is it correct? [Re: Iceman01] #914167
01/28/11 02:20 PM
01/28/11 02:20 PM
A12RTX2340 Offline
A12RTX2340  Offline
I looked at this car pretty hard. The #'s stamped under the front head say the bottom end was assembled approx 3 months and 1 week before the cars SPD. That scared me. The numbers on the tranny are a mess but the assembly date coincides with the SPD, less than a month before. Without seeing the car in person or getting close up clear pics of the Vin #'s showing the broaching marks you have to be skeptical or you can get burned, old ladies car or not (which is what this car is claimed to be by the seller). In big block land from my experience, engine assembly dates over 3 mo's (heck, 2 months is a stretch IMO) before the cars SPD screams possible restamp or in the very least you need to investigate/scrutinize the stampings further IMO to authenticate. Yeah, the car looks to be untouched but you never know till you look at it in person or get extremely detailed pics beforehand and even then..It's a cool car none the less. We are talking about a 71' 340 Duster car here BTW, and for what it's worth I at one point in time had a driver status survivor 73' 340 Dart Sport (all orig paint, guaranteed orig engine never opened up with orig gaskets till I opened it up to change the rear main seal) and the (orig paint still) engine assembly was approx 2 weeks before the cars SPD-I know were not comparing apples to apples here, 71' vs 73' anyway, but at least it's a 340 A-body to compare to. In my experience (admittedly mostly with big blocks), a couple weeks before and up to a month before the cars SPD seems to be the accepted "norm" for engine assembly dates and my personal experience with guaranteed original engines. You never know I suppose, SPD's are just that, scheduled, not guaranteed. I'd like to believe that is the original engine for the vehicle, you just need to thoroughly check it out before you pull the trigger if you truly want a guaranteed orig engine vehicle..and that probably means a visual inspection by you or someone knowlegeable in this case. If I was on the west coast I would have already checked it out.
Re: Font and vin number of engine block, is it correct? [Re: A12RTX2340] #914168
01/28/11 02:47 PM
01/28/11 02:47 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
I have seen a few big block LA built cars and all of them had very close engine assembly dates to SPD's. from a few weeks to a month.
Re: Font and vin number of engine block, is it correct? [Re: 70plymA34] #914169
01/28/11 05:44 PM
01/28/11 05:44 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
I've seen a few 70 model year LA built cars with original drivetrain assy dates in the Dec-Jan range, and the SPD's were in the March-April range. That being said, they are most likely the exception to the norm.
Re: Font and vin number of engine block, is it correct? [Re: rayztoy] #914170
01/28/11 06:22 PM
01/28/11 06:22 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
Once again nothng is the norm with these cars,LOL
Re: Font and vin number of engine block, is it correct? [Re: A12RTX2340] #914171
01/31/11 02:20 PM
01/31/11 02:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
On the most part I would agree but I think 1971 might be the exception. I think Chrysler did not expect the major drop off that they had in production from 70 to 71.
For example I have a 340 that is cast in February of 71 yet it has a 1972 VIN.
1971 might be a year of bad forcasting
Re: Font and vin number of engine block, is it correct? [Re: quick77rt ] #914172
02/02/11 10:58 PM
02/02/11 10:58 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Dec 1969 SBD .
LA plant - 1970 Challenger 340 auto
Re: Font and vin number of engine block, is it correct? [Re: gtx6970] #914173
02/02/11 10:58 PM
02/02/11 10:58 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
trans
