Wont idle in gear #913875
01/25/11 06:41 PM
01/25/11 06:41 PM
Illinois
I
intercooledrt Offline OP
I
Illinois
I have a 1971 Charger 383 HP with a 509 purple shaft cam, .30 over, roller rockers, Holley 750, MSD 6AL,727 w/ a 3500 stall, and I am having problems with the engine stalling when put into gear. I have messed with the timing, the idle set screws and still no luck with it idling properly in gear. I have to drive the car with both feet (one foot gas, one foot brake)
Re: Wont idle in gear [Re: intercooledrt] #913876
01/25/11 07:24 PM
01/25/11 07:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would plug the vacuum advance replace stock advance springs with light springs. then set total to 38. I would advance the cam to 102!
Re: Wont idle in gear [Re: Dodgem] #913877
01/25/11 07:30 PM
01/25/11 07:30 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
WOW and that will fix it with out even checking any thing else ?
I don't KNOW ABOUT THAT!
IF it were me i would start at the Basics , ignition first , vacuum check for leaks , then fuel in that order .
1969 Dodge Charger 1969 Dodge Superbee
Re: Wont idle in gear [Re: intercooledrt] #913878
01/25/11 07:55 PM
01/25/11 07:55 PM
Andrewh Offline
Andrewh  Offline
lets start at the begining.
first run on this motor?
or what did you change?
Re: Wont idle in gear [Re: Andrewh] #913879
01/25/11 08:35 PM
01/25/11 08:35 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
What RPM are you trying to idle at in and out of gear?
Initial timing?
Total timing?
If that cam is 248@50 initial should be between 18-20.
Re: Wont idle in gear [Re: intercooledrt] #913880
01/25/11 08:36 PM
01/25/11 08:36 PM
What AndrewH said. Just for a test I'd try setting the initial at 15-18 then the carb for a good idle in park then see if it'll hold it in gear.
Re: Wont idle in gear [Re: RapidRobert] #913881
01/25/11 08:48 PM
01/25/11 08:48 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
This is what happened to me,and it ended up being the converter.
Just wanted to run it passed you. The converter was new and after a few days it would no longer idle in gear. The stator locked up.
Just a thought.
Re: Wont idle in gear [Re: Darter6] #913882
01/25/11 10:00 PM
01/25/11 10:00 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
The PCV valve could be sticking, had that happen, it would idle in(P)or(N) but would die as soon as it went into gear.
Re: Wont idle in gear [Re: intercooledrt] #913883
01/25/11 10:24 PM
01/25/11 10:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My guess is not enough intial timing at idle and improperly setup dist. Bet ya
Re: Wont idle in gear [Re: Challenger 1] #913884
01/25/11 10:28 PM
01/25/11 10:28 PM
Outside
thedriver Offline
thedriver  Offline
Outside
make sure you arent too lean on the carb also. turn them air/fuel screws out a half turn then try it.
1973 challenger
Dana. 4 speed. Low deck.
Re: Wont idle in gear [Re: cjs69mope] #913885
01/25/11 10:51 PM
01/25/11 10:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had the same issue with my car and it turned out to be a bad ballast. It was droping the volts to the cil way down. As soon as I drop it in gear it would stall.
Coming soon!!!!
Re: Wont idle in gear [Re: Mr.Yuck] #913886
01/26/11 01:35 PM
01/26/11 01:35 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I'm going to go on a whim here and ask what type of airfilter are you using? I (dumba$$) had a restrictive aircleaner/filter on my first build many years ago and we stood there scratching our heads wondering why the car would stall *AFTER* we tuned it, timed it, etc... shut if off, put the cleaner on, started it, put it into gear and it died nearly every time.... well after this happening several times, we stopped to think what we were doing. Spent the $$ for a cheap mr.gasket airfilter/cleaner set up and bingo!! Problem solved.... have since upgraded from oh so long ago...
Just a thought....
Re: Wont idle in gear [Re: 67dodge67] #913887
01/26/11 01:43 PM
01/26/11 01:43 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If you still have the stock power valve,replace it with the correct one. I doubt you have enough idle vac to us the stock power valve. As others have stated distributor setup will be very important as well.
Re: Wont idle in gear [Re: goldmember] #913888
01/28/11 09:52 PM
01/28/11 09:52 PM
Illinois
I
I
Illinois
Thanks for everybodys input. I had a local speed shop set up the distributor and from what I remember he set it up to where timing is pretty much all there at start up. I have yet to get out to the garage and start messing with the car. Keep your thoughts and tips coming, I appreciate the help. Hopefully in the next week or two I will be able to get out and do some wrenching on it.
