Master Cylinder #913141
01/24/11 09:50 PM
01/24/11 09:50 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Can anyone tell me what the correct factory color of the master cylinder and cover was on a 71 B-body (Road Runner)that was equipped with power disc brakes ?
Re: Master Cylinder [Re: GETX] #913142
01/25/11 03:06 PM
01/25/11 03:06 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
What engine?
Re: Master Cylinder [Re: GETX] #913143
01/25/11 03:56 PM
01/25/11 03:56 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
If it's a hemi, the entire master cylinder is painted black.
If it is not a hemi, I believe the master cylinder is painted a gray color, almost resembles what I'd call parkerizing. Most of the NOS master cylinders I've seen for '71-'74 had this finish. I've seen some later NOS cylinders that had gold cad plated caps, but I don't think that is what they used in the early '70's.
Re: Master Cylinder [Re: Mastershake340] #913144
01/25/11 05:25 PM
01/25/11 05:25 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
If you have the Midland Ross booster (that was plated orig )on my late 71 car it had a parkerizing on the lid but the master looks natural finish. The orig parkerizing may have worn off but it was a orig 26k mile car when I got it in 84.
Re: Master Cylinder [Re: FJ5_Fish] #913145
01/25/11 06:15 PM
01/25/11 06:15 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
What engine?
383 c.i. console automatic w/factory a/c
Re: Master Cylinder [Re: THESHAKERPROJECT] #913146
01/25/11 06:20 PM
01/25/11 06:20 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Not that anyone cares about a 73 but that's the way mine was. Zinc Dichromate booster, natural master and natural(possibly phosphated?)cover.
I'm pretty sure now that the cover was NOT plated. The origonal cover had an even amount of surface rust all over it. I don't remember seeing any plating present. I noticed while cleaning up my fasteners that the plating is hard to get off completely.(even when bead blasting) If the lid had been plated, I'm sure some traces of it would have still been visable.
Re: Master Cylinder [Re: THESHAKERPROJECT] #913147
01/25/11 06:23 PM
01/25/11 06:23 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
I do have the Midland Ross booster that is cad plated. Is there any way to replicate this "parkerizing" that you refer to? Thanks to all for the info. and replies so far.
Re: Master Cylinder [Re: GETX] #913148
01/25/11 06:26 PM
01/25/11 06:26 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Some have used a product called Tool Black. I've had very nice results with a Black Oxide kit from Caswell Plating. By experimenting with dip times, you can produce a gray color that looks like phosphate. You could also send your lid out to be re-phosphated.
Re: Master Cylinder [Re: burdar] #913149
01/25/11 06:35 PM
01/25/11 06:35 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Some have used a product called Tool Black. I've had very nice results with a Black Oxide kit from Caswell Plating. By experimenting with dip times, you can produce a gray color that looks like phosphate. You can also send your lid out to be re-phosphated.
Great, thanks for the info. I will look into these products.
Re: Master Cylinder [Re: burdar] #913150
01/25/11 10:50 PM
01/25/11 10:50 PM
ohio
little buddy Offline
ohio
where can you send the cap.
