Re: 430" small block build
[Re: DJVCuda]
#912842
06/05/12 04:28 PM
06/05/12 04:28 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Yeah I saw it was a solid roller, IIRC that's the 'FlyFish' cam that works really well on the strokers, pulls better up high than you think it would on paper. I might try that one the next time I do a 'little 'un' Awesome combo, it would be awesome to swap the heads and test the intakes back to back just to see how far the RPM Ag can go....run the 1000HP on it though so we know it's not the carb holding it back. Seem to think the Ag's are great up to around 520-530 but with a big carb they might run further upstairs. I only run the Vic 'cause I'm trying to kill some bottom I know the SBM intakes aren't the 15 minute swaps (like Big brother) on the Dyno though.
[Re: DJVCuda]
#912845
07/17/12 01:54 PM
07/17/12 01:54 PM
Posts: 458 Michigan
BPE
What! It's going back on the dyno already? I thought you were trying to make this "The Marathon Engine Build" Just kidding, when does it go back on the pump? Rod
[Re: BPE]
#912846
07/17/12 01:59 PM
07/17/12 01:59 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
[Re: FlyFish]
#912848
07/17/12 02:24 PM
07/17/12 02:24 PM
DJVCuda
Atco NJ
[Re: Dunnuck Racing]
#912854
07/18/12 01:23 AM
07/18/12 01:23 AM
Posts: 2,141 junction city oregon
viperblue72
Maybe it's just me,but I don't think you will see much of a gain until you put the bigger camshaft in it. On the header subject,1 3/4" headers seem to be the ticket with mine. I ran 1 7/8" before thinking they were necessary. My dyno testing lately shows a hole in the torque curve that just does not get made up for up top with the bigger headers. In anything that launches at or below about 4500 rpm anyway,I am learning to like 1 3/4" headers more and more. Keith
No offense but I disagree that it won't be much gain. I had a 408 that was almost identical to this build, same cam. Went from mild eddies to indybrocks, and gained 4 mph in the 1/4. So I am going to guess 560-570 horsepower.
[Re: justinp61]
#912855
07/18/12 02:29 PM
07/18/12 02:29 PM
DJVCuda
Atco NJ
Same puny 1 5/8" headers?
for now - yes
[Re: viperblue72]
#912856
07/18/12 03:53 PM
07/18/12 03:53 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
No offense taken! We all have different ideas on what works and why. I just don't think the best exhaust port in the world can move enough air with that cam/header combination. I believe it will need different valve events to make much of a difference. If he steps up the header size before the cam swap,you will most likely see more. Besides,he is running stockish versus "ported" heads,not Indybrock's with a relocated pushrod pinch. Even if the flow numbers were similar,port volume and air speed isn't I would think it will move the peaks up the rpm range a few hundred rpm,maybe lose a little torque down low and gain a little horsepower. I don't usually guess numbers on these posts as I'm sure his dyno is slightly different from mine,but I would venture to say a 20 lbs-ft loss down low for 20 hp up top.
Keith
