Page 12 of 16 1 2 10 11 12 13 14 15 16
Re: 430" small block build [Re: DJVCuda] #912842
06/05/12 04:28 PM
06/05/12 04:28 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yeah I saw it was a solid roller, IIRC that's the 'FlyFish' cam that works really well on the strokers, pulls better up high than you think it would on paper. I might try that one the next time I do a 'little 'un'
Awesome combo, it would be awesome to swap the heads and test the intakes back to back just to see how far the RPM Ag can go....run the 1000HP on it though so we know it's not the carb holding it back. Seem to think the Ag's are great up to around 520-530 but with a big carb they might run further upstairs. I only run the Vic 'cause I'm trying to kill some bottom
I know the SBM intakes aren't the 15 minute swaps (like Big brother) on the Dyno though.
WIZE
In Car:
Re: 430" small block build [Re: Streetwize] #912843
06/05/12 04:37 PM
06/05/12 04:37 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
yeah it really makes thing time consuming -
I really like to let things sit for a day when I swap them - typically.
When it's spring and others are in line for the dyno to get the bullet in a car it's tough... we'll try and give it a go though
Re: 430" small block build [Re: DJVCuda] #912844
07/17/12 01:41 PM
07/17/12 01:41 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Any Guesses?
SDSS Stage 4 ported heads
2.055 intake valves
1.60 exh
and Eddy Victor 340 intake
Port and gasket matched
are the changes up next on the pump
Re: 430" small block build [Re: DJVCuda] #912845
07/17/12 01:54 PM
07/17/12 01:54 PM
BPE Offline
BPE  Offline
What! It's going back on the dyno already? I thought you were trying to make this "The Marathon Engine Build" Just kidding, when does it go back on the pump?
Rod
Re: 430" small block build [Re: BPE] #912846
07/17/12 01:59 PM
07/17/12 01:59 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
lol... maybe Thursday.
Re: 430" small block build [Re: DJVCuda] #912847
07/17/12 02:17 PM
07/17/12 02:17 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Same cam as before?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: 430" small block build [Re: FlyFish] #912848
07/17/12 02:24 PM
07/17/12 02:24 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
yes
Re: 430" small block build [Re: DJVCuda] #912849
07/17/12 03:23 PM
07/17/12 03:23 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
557 hp...and a boat load of torque.
Re: 430" small block build [Re: FlyFish] #912850
07/17/12 03:34 PM
07/17/12 03:34 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I'm hoping I loose some of that torque I made and make a little more HP this time around
Re: 430" small block build [Re: DJVCuda] #912851
07/17/12 03:44 PM
07/17/12 03:44 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Maybe it's just me,but I don't think you will see much of a gain until you put the bigger camshaft in it.
On the header subject,1 3/4" headers seem to be the ticket with mine. I ran 1 7/8" before thinking they were necessary. My dyno testing lately shows a hole in the torque curve that just does not get made up for up top with the bigger headers.
In anything that launches at or below about 4500 rpm anyway,I am learning to like 1 3/4" headers more and more.
Keith
Re: 430" small block build [Re: DJVCuda] #912852
07/17/12 03:45 PM
07/17/12 03:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Same puny 1 5/8" headers?
Re: 430" small block build [Re: justinp61] #912853
07/17/12 11:46 PM
07/17/12 11:46 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Re: 430" small block build [Re: Dunnuck Racing] #912854
07/18/12 01:23 AM
07/18/12 01:23 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Keith
No offense but I disagree that it won't be much gain. I had a 408 that was almost identical to this build, same cam. Went from mild eddies to indybrocks, and gained 4 mph in the 1/4.
So I am going to guess 560-570 horsepower.
Re: 430" small block build [Re: justinp61] #912855
07/18/12 02:29 PM
07/18/12 02:29 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
for now - yes
Re: 430" small block build [Re: viperblue72] #912856
07/18/12 03:53 PM
07/18/12 03:53 PM
Northern Indiana
Northern Indiana
Keith
No offense taken! We all have different ideas on what works and why. I just don't think the best exhaust port in the world can move enough air with that cam/header combination. I believe it will need different valve events to make much of a difference. If he steps up the header size before the cam swap,you will most likely see more.
Besides,he is running stockish versus "ported" heads,not Indybrock's with a relocated pushrod pinch. Even if the flow numbers were similar,port volume and air speed isn't
I would think it will move the peaks up the rpm range a few hundred rpm,maybe lose a little torque down low and gain a little horsepower. I don't usually guess numbers on these posts as I'm sure his dyno is slightly different from mine,but I would venture to say a 20 lbs-ft loss down low for 20 hp up top.
Keith
Re: 430" small block build [Re: DJVCuda] #912857
07/18/12 04:56 PM
07/18/12 04:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
just fyi Dave a 950hp will be the best bet,atleast on my similar motor it loved it to death,something about sb mopars(they love carburation)
Re: 430" small block build [Re: fishy340] #912858
07/18/12 07:25 PM
07/18/12 07:25 PM
V
viperblue72 Offline
viperblue72  Offline
V
Keith, I didn't think about the 1 5/8 headers and what restriction that may have. I was running tti headers on mine.
I figured a fully ported edelbrock may be similar to a indybrock. At least many argue that the flow #s are about the same. But moving the pushrod pinch may have an affect on track times, but not flow bench?
I am still gonna go out on a limb and guess another 40-50 hp.
Re: 430" small block build [Re: viperblue72] #912859
07/19/12 12:16 AM
07/19/12 12:16 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't think it'll pick up much, it may just move it up a little. However I think a good set of bigger headers will pick it up 20-25 hp without any loss of torque .
Re: 430" small block build [Re: justinp61] #912860
07/21/12 05:54 PM
07/21/12 05:54 PM
Northern Indiana
Northern Indiana
What's the word,Dave? Just curious if you made it to the dyno or not?
Keith
Re: 430" small block build [Re: Dunnuck Racing] #912861
07/21/12 06:27 PM
07/21/12 06:27 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Yeah Dave...I got another early 360 block lined up that is begging for a long arm, Don't leave us hanging
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
