Page 7 of 16 1 2 5 6 7 8 9 15 16
Re: 430" small block build [Re: DJVCuda] #912742
03/12/11 09:38 AM
03/12/11 09:38 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
just a thankyou for taking the time to show and explain all thats going on Dave and to the machine shop for letting all the work be seen Andyb
Re: 430" small block build [Re: fishy340] #912743
03/12/11 05:45 PM
03/12/11 05:45 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
you better go buy all these parts now..
cause when dave publishes it in a magazine...
the parts will all go to back orders...lol..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 430" small block build [Re: cheapstreetdustr] #912744
03/12/11 09:20 PM
03/12/11 09:20 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Thanks Andy - I see alot of people watching but not alot commenting, so thanks again for commenting.
Jim - lol - we are far from done... you should like the progression we go through when this sucker gets finished.
I'll get some pix up shortly of the valvetrain parts
Re: 430" small block build [Re: DJVCuda] #912745
03/14/11 09:29 AM
03/14/11 09:29 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
OK - a few updates - the heads are at Shady Dell Speed Shop to get the port work done.
The cam selected will require a 954 spring ( double with damper ). This required a tool steel retainer and 10 degree lock.
The lifters are the COMP 8043 lifters that have the link bars in the front as opposed to the older style 828 lifters. These should require no grinding on the block and since the block is tubed the ability of the lifter to pushrod oil is not going to be used.
Side shot of the lifters.
Re: 430" small block build [Re: DJVCuda] #912746
03/15/11 10:36 AM
03/15/11 10:36 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I am diggin it . I have the 828 in my block no problems at all. keep up the good work and pics
Re: 430" small block build [Re: Scamp408] #912747
03/15/11 03:33 PM
03/15/11 03:33 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Thanks - will do!
Re: 430" small block build [Re: DJVCuda] #912748
03/15/11 06:10 PM
03/15/11 06:10 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
.............and since the block is tubed the ability of the lifter to pushrod oil is not going to be used.
You do know, by not having oil pressure at the lifter, you are
giving up one of the another added features of that lifter?
EDM oiling to the needle bearing axle.
Re: 430" small block build [Re: S/ST 3040] #912749
03/15/11 10:08 PM
03/15/11 10:08 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
yes I am aware of the loss of oil direct to the axle. The 828's live with splash oiling.
In your opinion Vic - Do you think it will be an issue for my setup?
Re: 430" small block build [Re: DJVCuda] #912750
03/15/11 10:12 PM
03/15/11 10:12 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would want to take advantage of the direct axle oiling it should make them hold up even better.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 430" small block build [Re: DJVCuda] #912751
03/16/11 05:25 AM
03/16/11 05:25 AM
S/ST 3040 Offline
S/ST 3040  Offline
I would think the pressurised oiling would be benaficial in any
application. They should last as long as the 828, without.
Re: 430" small block build [Re: S/ST 3040] #912752
03/16/11 10:02 PM
03/16/11 10:02 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
WHOO HOO - - My cam is here....
Re: 430" small block build [Re: DJVCuda] #912753
03/19/11 10:14 PM
03/19/11 10:14 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Have not had much time lately, so not much to update - I have been collecting parts but as far as the bock goes - the 4 bolt mains are done.
The only PIA is the pro-gram supplied studs - if they had been setup for an allen head to run them down like the main studs it would save alot of time.
Re: 430" small block build [Re: DJVCuda] #912754
03/20/11 02:35 AM
03/20/11 02:35 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
This is a FUN read!!
One question: Why not a beehive spring??
Re: 430" small block build [Re: cudadoug] #912755
03/20/11 08:22 AM
03/20/11 08:22 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I was considering one but could not find anything even in the ballpark as far as spring pressures.
Re: 430" small block build [Re: DJVCuda] #912756
04/16/11 09:59 AM
04/16/11 09:59 AM
ohio
all spooled up Offline
ohio
hows it comeing along
Re: 430" small block build [Re: all spooled up] #912757
04/16/11 09:27 PM
04/16/11 09:27 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Gathering parts and working overtime right now.
Thanks for the bump!
Re: 430" small block build [Re: DJVCuda] #912758
04/16/11 10:49 PM
04/16/11 10:49 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Can you share any insight on the cam and head flow for this beast?....I happen to be running the same springs but with the Ti retainers.
also are you looking for a moderate RPM motor or a high-winder?
WIZE
In Car:
Re: 430" small block build [Re: Streetwize] #912759
04/16/11 11:09 PM
04/16/11 11:09 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I was prepared to go TI if I had to but Ryan recommended against them - stating they would get chewed up by the damper of the spring. I researched it and Manley and Comp also concur with Ryan. I never doubted Ryan, I just wanted to see if there was a common knowledge I was missing, and apparently the manufacturers are aware of the issue.
just an FYI - I have no idea on the longevity we are talking about but the tool steel is regarded when used with any damper.
Ryan was kind enough to spec out a comp custom roller for me to coincide with his heads - The comp specs:
Dur 258/262, Lift .639/645 w/ 1.5's
I'm looking at this point to make this a midrange motor - 3000 - 6500 - Ryan stated he could throw a bit more duration for more top end, but stated it was a safe, killer piece from 3200 - 6400.
Re: 430" small block build [Re: DJVCuda] #912760
04/16/11 11:58 PM
04/16/11 11:58 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
What kind of HP you looking to get out of it??
Re: 430" small block build [Re: MIKES_DUSTER] #912761
04/17/11 12:08 AM
04/17/11 12:08 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
as much as I can....
