Black wrinkle finish paint #912094
01/23/11 10:32 PM
01/23/11 10:32 PM
western new york
horsepower.2007 Offline OP
western new york
Anybody know which is the best wrinkle finish paint to use? I'm thinking eastwood?
Re: Black wrinkle finish paint [Re: horsepower.2007] #912095
01/23/11 10:33 PM
01/23/11 10:33 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
VHT makes it for several things and heat ranges, a pain sorta but a nice finish...maybe worth a look.
Re: Black wrinkle finish paint [Re: quick77rt ] #912096
01/23/11 11:42 PM
01/23/11 11:42 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Although I have not tried it myself, I have had a couple of different guys tell me that the Harley-Davidson wrinkle is the best they have ever used. And easy to get, too.
Master, again and still
Re: Black wrinkle finish paint [Re: DaveRS23] #912097
01/24/11 12:28 PM
01/24/11 12:28 PM
SE Pa.
LimeliteAero Online content
LimeliteAero  Online Content
SE Pa.
Ive used the Plastickote with results that I would call nice but maybe not so accurate. Its too wrinkly.....Is that a word?
Re: Black wrinkle finish paint [Re: horsepower.2007] #912098
01/24/11 02:42 PM
01/24/11 02:42 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I have a powder coating process if you are interested PM me.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Black wrinkle finish paint [Re: DaveRS23] #912099
01/24/11 03:17 PM
01/24/11 03:17 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
What are you painting?
I've had favorable results with both H-D and Duplicolor paint. I had better results using several light coats and placing it out in the hot sun.
Re: Black wrinkle finish paint [Re: cruzin] #912100
01/24/11 09:49 PM
01/24/11 09:49 PM
western new york
western new york
Painting a 70 340 air cleaner.
Re: Black wrinkle finish paint [Re: horsepower.2007] #912101
01/24/11 11:28 PM
01/24/11 11:28 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I used the H-D paint and let it sit in the hot summer sun afterwards and its textured but does not look correctly wrinkled at all.
Re: Black wrinkle finish paint [Re: 69Cuda340S] #912102
01/24/11 11:57 PM
01/24/11 11:57 PM
ohio
little buddy Offline
ohio
i use the cold air method
Re: Black wrinkle finish paint [Re: little buddy] #912103
01/25/11 01:28 PM
01/25/11 01:28 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I use Eastwood's Krinkle paint. Paint item 2 wet coats and then immediately put them in the household oven (elec) at 250-275 degrees for about 3 minutes. Comes out looking just like it should.
Re: Black wrinkle finish paint [Re: hemi70se] #912104
01/25/11 05:48 PM
01/25/11 05:48 PM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
I have used the VHT and baked it in the oven. Very correct looking on my valve covers. I think the air cleaners have a little less wrinkle though.
Re: Black wrinkle finish paint [Re: horsepower.2007] #912105
01/26/11 11:03 PM
01/26/11 11:03 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have used a heat gun or hot hair dryer before. That way you can control the amount of wrinkle. The thicker you lay the paint on, the more and higher wrinkles you can get. It's the same with heat. More heat, taller wrinkles.
So by juggling the amount of paint and the amount of heat, you can get most any wrinkle finish you want.
Re: Black wrinkle finish paint [Re: DaveRS23] #912106
01/26/11 11:08 PM
01/26/11 11:08 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I've been happy with the results I got from a rattle-can wrinkle paint I bought from Aircraft Spruce & Specialty Co.
The same advice applied to my results:
The thicker the coat and the better application of heat yielded the more "aggressive" wrinkles.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Black wrinkle finish paint [Re: 67SATisfaction] #912107
01/27/11 10:23 AM
01/27/11 10:23 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have used VHT and Plasticote already. I have also used another one, can't remember that one though. I have found that if I put down about two light coats to give the paint good adheasion and color base, then give it one real good heavy coat (try not to get any runs), then set it in the hot sun it crinkles up really nice and fast. You may have to turn it every few minutes to get a uniform wrinkle.
Re: Black wrinkle finish paint [Re: 70HemiGTX] #912108
01/28/11 12:01 AM
01/28/11 12:01 AM
western new york
western new york
You mean i have to wait til summer? (LOL)
Re: Black wrinkle finish paint [Re: horsepower.2007] #912109
01/28/11 08:09 AM
01/28/11 08:09 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
You could use your wife's oven to heat it up and dry it. But see how many brownie points that gets you.
Re: Black wrinkle finish paint [Re: 70HemiGTX] #912110
01/28/11 10:04 PM
01/28/11 10:04 PM
western new york
western new york
Do you think the fumes would give it away?
Re: Black wrinkle finish paint [Re: horsepower.2007] #912111
01/28/11 10:37 PM
01/28/11 10:37 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
heat guns work wonders
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Black wrinkle finish paint [Re: azmopar] #912112
01/29/11 12:43 AM
01/29/11 12:43 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Can you use a gas oven?
Re: Black wrinkle finish paint [Re: horsepower.2007] #912113
01/29/11 01:28 AM
01/29/11 01:28 AM
South East Virginia
Jimsome Offline
Jimsome  Offline
South East Virginia
I used black HD krinkle paint on a HD (the heads) and it came out well. But after a few years I wanted to take it off and chrome it and man was it hard to get off. LOL!
1969 Plymouth Sport Satellite currently restoring
