Page 3 of 5 1 2 3 4 5
Re: Tuning a Holley 750 [Re: Magnum] #911898
01/31/11 11:53 AM
01/31/11 11:53 AM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
When you snap the throttle open. Can you see the spring compressing?
I will have to look next time I am messing with it. The accel pump has a red spring. I know when I move the throttle at all (without the engine on) I can hear it squirt fuel.
Re: Tuning a Holley 750 [Re: Magnum] #911899
01/31/11 12:50 PM
01/31/11 12:50 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I was able to cure my bog with a 35 shooter...
Same here.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Tuning a Holley 750 [Re: Junky] #911900
02/01/11 04:50 PM
02/01/11 04:50 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I can't find any information in the instruction sheet for the size of the shooter that comes in this carb. How do I identify that?
Re: Tuning a Holley 750 [Re: Chilort] #911901
02/01/11 07:53 PM
02/01/11 07:53 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The shooter (squirter)should have a two digit stamping on it. The stamping would be on the side that is facing the middle of the carb.
(28=.028", etc.)
I have a carb that both squirters came from QF with no stamping which means .031" to them.
Note: the larger the squirter the "quicker" it will deliver the fuel and visa-versa.
Do you have any extra squirters to try?
Re: Tuning a Holley 750 [Re: YO7_A66] #911902
02/01/11 10:06 PM
02/01/11 10:06 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
(28=.028", etc.)
Nope. But, it is raining here and is supposed to rain through Saturday so I couldn't try anything out even if I wanted to.
Re: Tuning a Holley 750 [Re: Chilort] #911903
02/01/11 10:20 PM
02/01/11 10:20 PM
south carolina U.S.
DOUGG Offline
DOUGG  Offline
south carolina U.S.
That carb should have came with a 31 squirter.
Re: Tuning a Holley 750 [Re: DOUGG] #911904
02/03/11 03:53 PM
02/03/11 03:53 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Is there any advantage to this kind of squirter:
http://www.holley.com/121-135.asp
versus this kind of squirter:
http://www.holley.com/121-35.asp
I currently have the style similar to the 121-135.
What kind of jetting on the primary and secondary is just so high that it would indicate that I need to start looking for other sources for problems? My highway ping is still there (though it seems better in some ways) and I'd like to fix it.
Re: Tuning a Holley 750 [Re: Chilort] #911905
02/03/11 05:12 PM
02/03/11 05:12 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Did you confirm that the fuel is squirting as soon as the spring is depressed?
I had a vacuum secondary carb that I had to shim the primary side spring to get it to work properly too.
""My highway ping is still there (though it seems better in some ways) and I'd like to fix it.""
If you are still getting the ping at highway cruise/WOT, and since you are running the orange pump cam, then a larger squirter would delivery that pump shot quicker. I would try a 035 or a 040 (with hollow screw) for your next testing. If one of these fixes the ping, then you can back down on your main jetting as long as your plugs are looking good. Your pump cam might get smaller too with the bigger squirter.
It appears that it wants more fuel but the guess is "when" it wants more fuel.
BUMP for the reference on the 440/750 (Holley #80508S) jetting.
I found this info about the straight versus tube online:
The "straight" type are basically first design, and are for straight boosters. The "tube" type was developed to aim a straighter stream of fuel against the booster, usually a dropped booster venturi. As the fuel hits the booster venturi, it atomizes better than the straight type.
I have also read that most cases you can use the style that the carb came with.
Re: Tuning a Holley 750 [Re: YO7_A66] #911906
02/03/11 06:40 PM
02/03/11 06:40 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Yes, it is squirting right away. The spring compresses and then slowly lets out.
If it is pinging at WOT I cannot hear it. The ping starts when I am running around 75mph in 3rd and have to increase the throttle a tad to go up hill or pick up speed a little more. Then it rattles like a coffee can full of bolts. I would guess engine speed is about 2700rpm based on gear and tire size. Engine vacuum is still over 15inhg when this happens. If I get into the throttle more I can make the rattle go away. I'm guessing still to lean on the primary side. I'm currently still running the 78 jets on the primary and 84 on the secondary. I did drive the truck today and will check some plugs when I gethome.
Mine came with the straight types, so I guess I'll go with that.
Re: Tuning a Holley 750 [Re: Chilort] #911907
02/03/11 06:49 PM
02/03/11 06:49 PM
RapidRobert Online content
RapidRobert  Online Content
The ping starts when I am running around 75mph in 3rd and have to increase the throttle. If I get into the throttle more I can make the rattle go away.
Try turning the vac can 3 turns CCW w a 3/32" allen wrench
Re: Tuning a Holley 750 [Re: RapidRobert] #911908
02/03/11 06:53 PM
02/03/11 06:53 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Vac can is completely disconnected. I'm still trying to sort this out so I can then reconnect the vacuum advance and then go through all of this again.
Re: Tuning a Holley 750 [Re: Chilort] #911909
02/03/11 06:59 PM
02/03/11 06:59 PM
The Q (to me) is is it a lean prob or timing. I'd suspect timing (if your octane is adequate). I'm wondering if a slightly stiffer spring combo would help (& I'm assuming your total (w vac adv unhooked/capped as it is now) is correct for the eng family 35-SB 36-38-BB.
Re: Tuning a Holley 750 [Re: RapidRobert] #911910
02/03/11 07:03 PM
02/03/11 07:03 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I'm running about 35* total advance all in around 3500rpm. I have it slowed way down with a heavy spring package and spring perches bent a bit to get it that slow.
I've run more and less total timing and I've never been able to make the ping go away with timing. I'm hoping it is lean and I can get some of my timing back once I figure out what is going on.
Re: Tuning a Holley 750 [Re: Chilort] #911911
02/03/11 07:08 PM
02/03/11 07:08 PM
Yeah you are not overboard w timing. Holler how it turns out. Didn't read all the posts & dont know if more octane is a practical option for you but that's my guess
Re: Tuning a Holley 750 [Re: RapidRobert] #911912
02/03/11 10:02 PM
02/03/11 10:02 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Pulled 8 plugs and they look gray to me. No signs of light brown/tan color. I must still be too lean. I'm thinking of going with 82s on the primary and 88 on the secondary side......
Re: Tuning a Holley 750 [Re: Chilort] #911913
02/03/11 10:13 PM
02/03/11 10:13 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Something else is wrong. you need to start looking for something else. I'd be surprised if that carb needed to be changed 2 jet sizes.
What is your fuel pressure when you are cruising and at part throttle?
Re: Tuning a Holley 750 [Re: Chilort] #911914
02/03/11 10:26 PM
02/03/11 10:26 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""The ping starts when I am running around 75mph in 3rd and have to increase the throttle a tad to go up hill or pick up speed a little more.""
Your running Champion RC12YC plugs,high pump octane (93), 9.2 compression, no vac advance, timing at 3500, orange pump cam/031 squirter, 78 primary jets, and you still have pinging at light accel at 2700rpms and 15hg vacuum. HMMMMMM.
This problem may get worse as the outside temps go up, unless you are lean. I still suggest that you try the 035 or 040 squirter.
My second thought is that the plugs are tooooo hot in the range.
What heat range Champion spark plugs are other members running on the street? Are 12's too hot?
Re: Tuning a Holley 750 [Re: Chilort] #911915
02/03/11 10:39 PM
02/03/11 10:39 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
what is your cranking compression psi ?
per haps you have too much cyl psi ?
may need to back off timing to 32-34 deg total .
Re: Tuning a Holley 750 [Re: calrobb2000] #911916
02/03/11 11:23 PM
02/03/11 11:23 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I just tried some Autolite plugs that are in the same heat range as a Champion 9 because I have them sitting around. ....same result.
I bumped up the primary to 82 and secondary jets to 88. .... same result (and too dark out to tell if I was leaving a cloud of black smoke behind me).
I've never checked the cranking pressure. The cam was installed straight up and verified that it is straight up.
I've never checked the fuel pressure either. I don't have a port and I don't have a fuel pressure gauge that reads this low (mine is for fuel injected stuff). The fuel pump is a new Carter replacement style pump.
I do need to get a bigger squirter but that'll have to wait for the weekend.
Re: Tuning a Holley 750 [Re: Chilort] #911917
02/04/11 01:13 AM
02/04/11 01:13 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
This has a rear sump pan and a windage tray. We had to heat and bend the rear sump pickup a bit to get the tube to clear the windage tray and still stay off the bottom of the pan. I wonder if at specific engine speeds the oil pump pickup is oscillating and hitting the windage tray. That pickup is a snake-y thing and I could see it doing that. But even if it did I doubt it would be loud enough for me to hear.
I'm grasping at straws.
