A side project to get me away from the floorboard project which is dragging on forever!
Maybe I should be fielding this to Demon Dave but hes always busy testing tuning and rebuilding so in the event hes not out there in Moparts land. I know there are TQ owners out there...so I'll gladly accept suggestions from other TQ peeps...
TQ is a 9097S Application was 1976 Lean burn 400 with Auto.
Stock parts include Primary 4099 Sec 5413 Rod 2086 1.5inch pri bores so its an 850 CFM. Has the dual booster venturies.
Car 66 Coronet w 440HP TRW flat tops 906 heads and a 484/284 MP Cam - Headers and stock 4hole intake at the moment. Using an open 4bbl square to 4bbl spread adapter. I know a 4hole adapter would be better but its what I have...and I used it that way as a daily driver years ago.
I rebuilt the TQ all stock xcept new idle mixture needles I bought from Demon sizzler years ago that he said would provide more tunability...and they do seem to. Also bought a new set of o-rings from him since they left em out of my kit so its not leaking from the o-rings.
Sooo post rebuild....it idles but is SMELLLYYYY!!
Lean Burn carb? Nothing LEAN about it at idle and its
BURNing my eyes!!!
On the plus side...I probably killed every mosquito for 2 blocks.
I tried turning the slow idle screw low as I could to cover the idle transfer slots as much as possible and still get a stable idle. Adjusted the timing a bit too. Sounds like its idling about 800 - 1000 in neutral and around 600-700 at idle but Im gonna use my shop tach tomorrow to verify. Mixture screws are out approx 1 3/4 turns. They are functioning and it tries to stall if theyre closed all the way. I set them by ear to max rpm. Idle is fairly smooth.
Question is...HOW do I lean this thing out? I was always taught to adjust mixture screws to max engine vacuum or rpm depending on what equipment is handy while achieving the smoothest idle...but its makin my eyes red and I smell like an exhaust pipe! Do the mixture screws adjust air or idle fuel? If they adjust air...turning them out leans it. If they adjust fuel...turning them out richens it. Seems like the way everything is routed end result is they adjust fuel flow at idle from the boosters?
The metering rod tree seems to be all the way down even tho I only have around 15in of vacuum at idle with this cam. I adjusted it prior to installing the carb but need to fine tune it now that my idle is set. Do metering rods and main jets affect idling at all? Im askin bcus if metering rods don't affect idle fuel I'm yankin em out for now till I get to fine tuning it for performance bcus it repsonds much quicker without them. I used to drive it that way on the street but it wasnt great for fuel mileage. It stunk at idle back then too. The rods are still in place right now.
BTW I already drilled 1/8 holes in the primary plates years ago bcus it used to sit on a high rise intake but I mig'd them closed 2 days ago bcus after I fired it up it wouldnt idle down. Turns out I had a bad base gasket which I replaced with a new one and the accelerator cable was pulling on the throttle a bit so those holes may or may not have needed to be filled. I'd rather not re-drill them If I dont have to.
Thanks in advance for any suggestions
