U joint attachment? #91125
07/20/08 12:11 AM
07/20/08 12:11 AM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
Need the straps and bolts that hold u joint caps to pinion yoke. This is a 1975 RR, the rear axle assy. has factory disc brakes. Although the door handles have decals that say "4 wheel disc brakes" someone said that it had to be an Imperial rear end?
Anyways, the bolts are approx. 1/4 threaded into the pinion yoke, (came with the junk Moroso caps) Are there many different cars that have the same straps,or did they use a lot of diff sizes?
Would dealers have them, or do any of you have any?
Re: U joint attachment? [Re: bcr] #91126
07/20/08 01:01 AM
07/20/08 01:01 AM
you mean these little buggers?
Re: U joint attachment? [Re: RapidRobert] #91127
07/20/08 01:08 AM
07/20/08 01:08 AM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
Looks like that just might be. Never found the OEs with this car. Bought the Moroso scrap as it was avalible.
Re: U joint attachment? [Re: bcr] #91128
07/20/08 01:13 AM
07/20/08 01:13 AM
yeah these are for the std 7260(small)u joint. My driveshaft front yoke isn't engaged enough I need to get another before I have a problem.
Re: U joint attachment? [Re: RapidRobert] #91129
07/20/08 01:40 AM
07/20/08 01:40 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
