1984 D350 Crew Cab Dually Dealer installed A/C -- so the heat controls are all jacked up and laying flip-flop-loose in the dash - the temperature slider is frozen, and the Heat/AC slider doesn't seem to do squat. Can I do a custom home-fabricated re-do on this whole mess? Has anyone here ever trouble-shot this same issue and performed a home-remedy fix? It's so hard to find replacement parts since it's a dealer installed deal - and I just want it all to work - regardless if its a custom fix. Help....? Thanks for your inputs, Ron
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
