727 tranny woes #909955
01/20/11 09:34 PM
01/20/11 09:34 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
My 2nd gear has finally gone in my 70 Satellite. With that said, I have a few xtra 727's in my storage building. But they came off of 2 barrell 383 engines. Is there any performance difference between the 383 setup and a stock non HP 440 setup. My current engine is a mild built 440 with a 727 tranny from a stock non hp 440 motor. Will my 383 727 tranny be ok behind this engine? Side Note: Getting my other one rebuilt this summer but I just need her drivable now. Thanks in advance for your advice
Re: 727 tranny woes [Re: roy2345] #909956
01/20/11 10:05 PM
01/20/11 10:05 PM
scratchnfotraction Offline
yes,it will be fine
make sure to use the correct TC balance if it is different between them
have you adjusted the band?
I have lost 2nd gear a few times and it just needs the band adjustment
the more threds the adjuster that stick out the better,when all the way in the band is used up
I done this up to 3x on a 904 before needing a swap
as long as there is no other mech failure that is
Re: 727 tranny woes [Re: scratchnfotraction] #909957
01/20/11 10:14 PM
01/20/11 10:14 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
so to adjust the bands: i turn counter clockwise to tighten the band and clockwise to loosen? Never done that but thats probably why I messed this one up. Adjust this before I put in the car or after? Secondly, what stall is that TC likely?
Re: 727 tranny woes [Re: roy2345] #909958
01/21/11 02:21 AM
01/21/11 02:21 AM
The adj screws are regular right hand thread so CW (in) would tighten the band(s). CW (in) to 72 in lbs (snug) then backed off a certain # of turns ie 2 or 2&1/2 then lock it w the nut holding the bolt at that position w a screwdriver
Re: 727 tranny woes [Re: RapidRobert] #909959
01/21/11 04:03 AM
01/21/11 04:03 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Broken band, or clutches about burnt out, how does your fuel smell? Burnt? Needs a Rebuild. The other trannies that you have, what are the #s on the trannies ?
Re: 727 tranny woes [Re: 268RTs4ME] #909960
01/21/11 05:30 AM
01/21/11 05:30 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
POP-the-pan ... look to see what trash is there ...check the quality of the fluid and check the band-lever action on the front and rear ....and then report back.
