Strut Rod Thread Size/Pitch?
#908907
01/19/11 09:15 PM
01/19/11 09:15 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
After removing the strut rods from my Valiant I noticed some pretty nasty rolled threads on one. Explained why it was so hard to take the nut off, but now I need to fix it. What's the thread size? I have the fine threaded ones, and for sake of those searching in the future, we may as well get the thread size of the large threaded ones too. Thanks Mopartiers!!!
Re: Strut Rod Thread Size/Pitch?
[Re: rabid scott]
#908908
01/19/11 10:24 PM
01/19/11 10:24 PM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
K-frame end - 5/8-11
control arm end ? I'll ck tomorrow and update this unless someone else beats me to it
ps, these is the size for B + E bodies. I don't know if the A bodies are different or not
[Re: autoxcuda]
#908912
01/20/11 04:07 PM
01/20/11 04:07 PM
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
I thought I've seen A-bodies with booth fine and coarse threads on the bushing end. Certain year cutoffs? I'm I dreaming and they are all fine thread?
According to other threads I researched there are both fine and course threads on A-body strut rods. In fact on one thread there was a guy with a Demon where somewhere in the car's past one strut rod was replaced so he had one fine threaded one and one course threaded one.
[Re: rabid scott]
#908913
01/21/11 06:24 AM
01/21/11 06:24 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Same goes for torsion bar adjuster bolts. Fine and course thread.
