Axle offset question #908863
01/19/11 07:28 PM
01/19/11 07:28 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Need axle offset for a 67 b-body 8-3/4 rear end??? can I find it in the past posts somehow?? Thanks Swifter
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Axle offset question [Re: swifter] #908864
01/19/11 08:27 PM
01/19/11 08:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Do you mean pinion offset? The pinion is offset to the right 1 3/16".
Re: Axle offset question [Re: swifter] #908865
01/19/11 08:28 PM
01/19/11 08:28 PM
scratchnfotraction Offline
brake offset?
Re: Axle offset question [Re: scratchnfotraction] #908866
01/20/11 01:00 AM
01/20/11 01:00 AM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
I want to order rear disc brakes from wilwood and they asked if the axle offset was 2.36 or 2.50??? I was told you measure from the retainer face to the axle face where the tire mounts,But car is in storage with no access to it. I was wandering if i could find that out here??? Thanks Swifter
Re: Axle offset question [Re: swifter] #908867
01/20/11 10:24 AM
01/20/11 10:24 AM
you want the brake offset measurment..
A-body only axles have the small brake offset for the 1 3/4" brakes/backing plate
B-body axles have the large brake offset for the larger brakes/backing plates
what size brake on it now?
do the disc brakes work with green bearings? what kit? (doctor diff sell a nice package )
I dont recall the measurement for the offset right off
i can check my spare axles later though
Re: Axle offset question [Re: scratchnfotraction] #908868
01/20/11 08:41 PM
01/20/11 08:41 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Right now I have Drum on the rear,I'm changing axles and what to up-grade to disc on the rear and wilwood needs the axle offset so I can order the kit--Steve
Re: Axle offset question [Re: swifter] #908869
01/20/11 08:46 PM
01/20/11 08:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The B body will have the 2.5" standout. (offset)
