Anyone Running 71 B Body with TTI Exhaust? #908262
01/18/11 07:12 PM
01/18/11 07:12 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Wondering if there's any problem with tailpipes and the rear sway bar. I'm using the Firm Feel sway bar.
Re: Anyone Running 71 B Body with TTI Exhaust? [Re: dart4forte] #908263
01/18/11 08:12 PM
01/18/11 08:12 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Mine had a full TTI 3" system on it when I bought it. No swaybar, but I can tell you that the tailpipes did rub the shocks a little. I took the tail pipes off and just use turndowns on the mufflers.
Re: Anyone Running 71 B Body with TTI Exhaust? [Re: pinkduster] #908264
01/19/11 11:42 PM
01/19/11 11:42 PM
Northern NJ, U.S.
71X-mark Offline
71X-mark  Offline
Northern NJ, U.S.
I also have a complete 3" TTi exhaust system on my '71GTX, and have not encountered the tailpipe interference issues you mentioned. However, this may be due to having cut off their welded hanger at the back end so I could slide on original type exhaust tips (for 3" pipes) and hook them into the correct hangers, just as they were attached at the factory. Adjustment flexibility of the factory setup is limitless compared with TTi's method.
Re: Anyone Running 71 B Body with TTI Exhaust? [Re: dart4forte] #908265
01/20/11 12:16 AM
01/20/11 12:16 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I too will be using the firm feel sway bar - i see no issues as its mounted about the rear diff opposed to being mounted below like oem...
