I'm using that 1/2 inch spacer under the front studs to lean mine back a bit. I sit too high in my car too. I don't remember it being so high, but I think the new foam I installed gave them a boost.
I don't think you can do too much about it unless you eliminate the seat's slider mechanisim and make your own fixed mount.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
