Re: What year did dodge truck trans get better [Re: Chilort] #907139
01/17/11 11:07 PM
01/17/11 11:07 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My '00 Dakota R/T has almost 175,000 on it on the original drivetrain. (Even U-joints too) Only trouble I ever had with the trans was the little clip that holds the boost valve in broke and it started throwing a code. (140,000 miles) I took it to a local dealer and was told that "it needs a complete overhaul". I pulled the VB myself, took the VB out of a trans I bought off the Internet, and swapped them. Trans has worked fine ever since. I have raced the truck, hauled more crap than you can imagine, and pulled my race car trailer with it.
I still get people telling me I better not pull the trailer in OD or it will kill the trans.
I change fluid/filter every 30,000.
Re: What year did dodge truck trans get better [Re: slantzilla] #907140
01/18/11 01:12 AM
01/18/11 01:12 AM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
I'm with the believers ... my 2005 3500 CTD auto with a Reading service body (truck and tools weigh 8500) has over 150,000 on the original trans ... change the fluid and adjust the bands every 50,000 and no trouble what so ever ... oh yea I regularly (twice a week ) pull a 7500 lb trailer to and from job sites ... if you service them they last longtime
Re: What year did dodge truck trans get better [Re: 68_CONV_300] #907141
01/18/11 02:57 PM
01/18/11 02:57 PM
GA
Boosted Offline
Boosted  Offline
GA
I would remind everyone that those who have the diesel trucks and the auto that has lasted is not bombed....
Put any real hp/tq to it and it will die quickly.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: What year did dodge truck trans get better [Re: Boosted] #907142
01/18/11 03:06 PM
01/18/11 03:06 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
That is pretty much what happens to any brand stock trans. If you don't build the trans to take increased motor power then you have only done half the job.
Re: What year did dodge truck trans get better [Re: Boosted] #907143
01/18/11 04:30 PM
01/18/11 04:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I deleted my muffler and tweaked the pump on my 92 Cummins when the truck had 127,000 miles. The transmission started slipping in OD at 273,000 miles. When I tore it down there was nothing wrong inside. All the friction materials were in great shape and the steels had no signs of heat. There was no debris in the pan.
The seals were bad.
Not bad for a truck that has been raced, off roaded, jumped, used for hauling, and thoroughly abused.
- Stu Harmon
Re: What year did dodge truck trans get better [Re: Boosted] #907144
01/18/11 04:37 PM
01/18/11 04:37 PM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
So you mean if I make 50% more HP and torque than the factory designed it for it will not last
Thanks for the input there Captain obvious
Re: What year did dodge truck trans get better [Re: 68_CONV_300] #907145
01/18/11 04:55 PM
01/18/11 04:55 PM
GA
Boosted Offline
Boosted  Offline
GA
Thanks Private Ryan...
What I am saying is that if you leave the older autos stock they will last..
As I said earlier the newer 6spd autos will last with the additional hp of say 150hp. The old one like you have and older will not..
So the newer trans are stronger... That is when they got better as per the question of the original poster.. I did not see him ask anyone how to maintain one...
As far as pre 2000.. I like the 47rh better than the re...
2011 RAM3500
Re: What year did dodge truck trans get better [Re: feets] #907146
01/18/11 06:32 PM
01/18/11 06:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pulling hard with the lock up converters would lead to converter clutch failure. That sent debris through the system and OD would fail.
I'm not sure if the problem would go away with regular servicing or if the converter clutches were simply too weak for heavy duty use.
I agree. I've overhauled a few that check valve in the trans line near the regulator became clogged. I believe it was with debris from the torque converter clutch. This blocks the return from the cooler which doubles as the lube feed for the overdrive. No lube spells disaster.
Doug
Re: What year did dodge truck trans get better [Re: dvw] #907147
01/18/11 08:04 PM
01/18/11 08:04 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
Got an 01 ram with the 46re with 120k and no troubles.
But the 98 durango with the 44re at 150k went out
Re: What year did dodge truck trans get better [Re: generallee6901] #907148
01/19/11 01:46 AM
01/19/11 01:46 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The problem with the lock up converters was not the fact it was lock up. The problem is they try to make all the shifts real smooth so customers don't notice the shifts, %99 of customers want a silky smooth shift. To get a smooth shift you engage clutches and bands more slowly, this allows them to heat up and burn then fall apart. The old fluids that chrysler used allowed the clutches to grab each other faster and burn less but shift harder. The ATF+5 is very low friction for smooth shifts and is bad in the trannys that were originally desighned for the higher friction fluid, the low friction fluid was a cheesy way to soften the shift. I worked at a dodge dealer in 01 and 02 and we replaced TONS of trannys. It was NOT an issue of service or not as 1/2 of them were not even due for their first service. They had new TSBs almost every year for all sorts of little things in those trannys, I like most people figured I was just seeing the worst in a manufacturer because I was a dealer tech, then I went to Toyota and replaced 2 a year instead of 2 a week. The newer mopar trannys are much better at dealing with the crappy new fluids unlike the a-500 and 518s that were desighned to work with the old high friction fluid. I always use Type-F when I build a tourqueflite based trans and have not had a single comeback on one (knock on wood).
Re: What year did dodge truck trans get better [Re: 6T6Cuda] #907149
01/19/11 05:00 AM
01/19/11 05:00 AM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
I know they had a lot of trouble with the dodge truck trans (overdrive). I am looking to buy a truck what year did they get better - if ever?
I am mostly looking at stuff before 2000
The 4 speed automatics on the 1989-2001 Ram trucks are a crapshoot. It really depends how the transmission was maintained, how the truck was driven, etc. I don't know if there was a "good year" for these transmissions. Some transmissions can last a long time and other will fail within a short period of time.
If you are concerned about transmission reliability, I would look at a 2002 & newer Ram truck with the 4.7L or 5.7 Hemi V8. The 545RFE automatic transmissions in these trucks are more reliable and tend to have a better service record than the old 4 speed automatics.
Just my
Re: What year did dodge truck trans get better [Re: Wheeler] #907150
01/19/11 10:44 AM
01/19/11 10:44 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
There is a TSB
about defective d-ring seals
being used by the factory after a supplier switch
in 46RH and 47RH automatics,
starting in late 1993
and corrected in late 1997
if I remember correctly.
I think the 46RH was basically a good design,
but the defective seals caused problems.
When the 46RE came in 1996
along with the OBD-II PCM system,
I believe the new VFS caused a lot of problems by simply failing,
and further problems by reducing the ATF fluid flows in a
'penny-wise, pound-stupid'
attempt by Chrysler to improve MPG slightly.
The SAE paper # 982674 by Chrysler
{see attachment}
does show in the graphs where they compare four different ATFs
that the Chrysler ATF+4 (9602) fluid had less friction clamping ability than the ATF+3.
I know that soon after I switched to ATF+4 in a 1995 46RH,
I was initially happy that there was less 'bump shift' when coasting to a stop as the trans downshifted into 1 st gear,
but my torque converter lockup clutch began to slip.
Re: What year did dodge truck trans get better [Re: 6T6Cuda] #907151
01/19/11 10:53 AM
01/19/11 10:53 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
From a dodge/GM service tech.
There never was really anything wrong with the 518 through the 48RFE. The customers just didnt want to pop them out of OD. Yes the earlie trannies had less fluid flow to the overdrive unit, but not starving it. My dads 97 Dodge 1 ton van had 285000 miles on it, he is in the floor covering business, he bought the Van with 14000 on it and when the tranny did chuck out he got it burried in a snow drift, and rocked it to sleep. So I rebuilt that tranny and the van has well over 350000 on it now and still rockin.
My 91 Dodge Cimmins has the non lock up 618 overdrive in it, and its te origional tranny at 198000 miles. It still shifting GREAT, and when I serviced it it was blood red with minimal debris in the pan. It is going to need a Kit when I get done wakeing up the Cummins, but its still fine in stock form.
I really think the whole Dodge = Crappo overdrive trannies is an overblown myth.
Kasey
Re: What year did dodge truck trans get better [Re: Moparnut426] #907152
01/19/11 06:15 PM
01/19/11 06:15 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Kasey
My 94 Cummins used to kick itself out of O/D at 70 mph in cruise whenever it felt like it, scared the crap outta me a few times, like being slammed from behind, then the torque converter used to lock and uplock and essentially 'hunt' between 1800 and 2000 rpm while driving at 70. I unloaded it for an 01 6 speed HO stick and never looked back.
Any truck, IMO, that will see some real work, should have a stick, period...flame on...
Re: What year did dodge truck trans get better [Re: Sixpak] #907153
01/19/11 09:37 PM
01/19/11 09:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
i'm rebuilding my 06 3500 trans now as i speak (cummins 42,00 miles) i found a few things that contributed to the clutches and band failure. the o-ring on the reaction shaft was not there which made a pressure loss for the converter, and the second gear lever is a 5.0, these were used on the hemi-sixpack cars back in the day and they have to be adjusted quite often.my fault on that.i'm not sure if the electric line pressure is working to well either. i agree that the fluid is to slick so i use ford type-f in my racing trans also. never had a problem in 35 years of racing. also my 92 diesel had 185,000 and no problems except the throttle pos. switch for overdrive kept going bad.
Re: What year did dodge truck trans get better [Re: 360view] #907154
01/20/11 09:39 AM
01/20/11 09:39 AM
USA
3
360view Offline
360view  Offline
3
USA
Sonnax lists these problems:
http://www.sonnax.com/system/assets/3108/original/SC-46-47RHE.pdf?1289884064
Some (not all) of the TSB's
are online thanks to Dave Fritz:
http://dodgeram.info/tsb/group_21.htm
