Re: Camshaft position sensor 2000 Neon
[Re: jdg68]
#906800
01/16/11 09:10 PM
01/16/11 09:10 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It certainly wouldn't hurt to clean the connections. I have had water get in them when washing the engine and it will cause problems. But I have seen them pretty well oil soaked without having any issues.
That oil leak is very common. Usually cleaning the little o-ring and applying Hylamar will fix it.
Also, make sure one of the leads didn't break. They can get brittle and as short as they are they must be strained a good bit to get the plug off the sensor.
Master, again and still
