Help with Strut removal
#906685
01/16/11 06:38 PM
01/16/11 06:38 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
I am on the last leg of the teardown for my disc brake conversion. I want to take the struts off and blast and re-paint them. I can't seem to be able to get them off. When I try to loosen them they just spin in the k-frame/rubber. Any suggestions are welcome. I have tried a pipe wrench on them to no avail...
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
Re: Help with Strut removal
[Re: buildanother]
#906688
01/16/11 07:08 PM
01/16/11 07:08 PM
68 Sat
Northern NJ
i am afraid that is how it probably should be done, but I am all torn down with the exception of these..and the service manual has them coming off towards the end on disassembly..
1956 Desoto Hemi
1955 Chrysler C300
[Re: CYACOP]
#906691
01/16/11 11:08 PM
01/16/11 11:08 PM
Posts: 761 Raleigh, NC
John426
super gas
super gas
Raleigh, NC
Put the lower control arm back in, I assume you haven't pulled the pivot out of the LCA quite yet, yes? Slide the torsion bar in place and tighten the LCA pivot nut. There should now be enough 'triangulating" force to hold the strut rod in place while you use an impact to loosen the nuts.
If that is not an option, then cutting the nut off as suggested above with the final little bit via a chisel is the best solution. You do not want to nick the strut rod. Yes you can file it, but ask yourself where 100% of the forces in the car at 100mph go when you hit the brakes. about 20% of the force is the rear brakes, the other 80% is split between the two front strut rods. As the brakes try to stop the wheels, it is the strut rod that is pulled rearward and stops the car. Think about it. Those rods are wicked strong in tension..... until you nick it for a stress riser.
Free advice, worth what you're paying (smile), but the cost of the new nut is fairly low.
John P.
[Re: John426]
#906692
01/16/11 11:29 PM
01/16/11 11:29 PM
68 Sat
Northern NJ
thanks John. I had to chisel one of the LCA pivot nuts off already, so I am going to try your advise and put a few pieces back together and see what happens. Thanks
1956 Desoto Hemi
1955 Chrysler C300
[Re: hemigod426]
#906695
01/17/11 12:55 AM
01/17/11 12:55 AM
68 Sat
Northern NJ
Everything is out except the struts. LCA, UCA, shocks, torsion bars, brake assembly. I guess I'll try the suggestions above and go from there. Thanks guys I'll keep you posted..
1956 Desoto Hemi
1955 Chrysler C300
[Re: 68 Sat]
#906696
01/17/11 08:57 AM
01/17/11 08:57 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Dont worry if you knick the strut rods.Just clean them up if you do.I used 2 pairs of big vice grips on mine next to each other.They dont do anything except to keep the lower arm in place.They arent like torsion bars that are a spring.I replaced mine a few years ago with RMS ones.Much better than stock.Rocky
Chrysler Firepower
