Re: Autolite 65
[Re: monoptn]
#906456
01/16/11 02:42 PM
01/16/11 02:42 PM
RapidRobert
I run em in my 318 & I'm pretty sure it's a resistor. I'm not a stereo guru (I'd rather listen to the eng) but I think it's gonna take a specialized filter (of some sort) to stop the amt of static you are reporting
Re: Autolite 65
[Re: scratchnfotraction]
#906460
01/17/11 02:05 AM
01/17/11 02:05 AM
Posts: 612 Nampa, ID
None2Slow
Nampa, ID
Check your grounds. You need to ground the engine to the frame and the body, with more than 1 connection each. It's almost always a bad ground that is attributed to radio noise. Make sure you check the radio as well as any amps you have.
Re: Autolite 65
[Re: monoptn]
#906462
01/17/11 08:53 AM
01/17/11 08:53 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
What wires are you running?When I ran Moroso solids they created a lot of radio noise.Rocky
Chrysler Firepower
