Valve covers with Crane Gold rockers #905572
01/15/11 08:19 PM
01/15/11 08:19 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
I am using Stealth heads with Crane gold roller rockers with aluminum block hold downs,my 70s vintage Cal custom valve covers will not fit, they rub on the end blocks. Other then grind them down does anyone use the same setup as this and can recommend a valve cover that will work, Thanks, Rodger
Re: Valve covers with Crane Gold rockers [Re: 69 GTX] #905573
01/15/11 11:12 PM
01/15/11 11:12 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
M/T valve covers fit great and seal awesome,if you can find a set.Got Crane golds under mine,too!
John
Re: Valve covers with Crane Gold rockers [Re: jcastle1] #905574
01/15/11 11:35 PM
01/15/11 11:35 PM
GA
Boosted Offline
Boosted  Offline
GA
I use a set of the sheet metal fab covers for my car..
No problems sealing and they will clear any rocker setup
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
