Page 8 of 10 1 2 6 7 8 9 10
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905395
06/07/11 11:39 PM
06/07/11 11:39 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
46
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905396
06/08/11 07:14 PM
06/08/11 07:14 PM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
what a sweet setup. im getting so many ideas. what front suspension is it?
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: Osyman] #905397
06/08/11 07:42 PM
06/08/11 07:42 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Direct Connection Spool type K-member and converted to 1973 Disc brakes. Original 383 "S" torsion bars and monroe shocks and factory "S" sway-bar.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905398
06/08/11 11:27 PM
06/08/11 11:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Looks ready to kill! I just put the blue monroes on my Dart and wow those are not a bad shock at all I gotta say.
Mopar to the bone!!!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: 72Swinger] #905399
06/09/11 04:57 AM
06/09/11 04:57 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Waiting is killin me! Got a little sheetmetal work to do before I get it in sealer. Then I can cut the jambs in and put the glass and doors back on. Then I can post some video.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905400
08/03/11 08:47 PM
08/03/11 08:47 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Any updates?
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: 69B3GT] #905401
08/03/11 10:11 PM
08/03/11 10:11 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Any updates?
Too darn hot here to do much of anything. 104 for the last few days and 103 thru the weekend. Been breaking heat records for a month too. Then add the humidity! My metal shop is a furnace in the worst way. No rain in months.
Engine is complete and sitting in the car but it has to come back out so I can wrap the headers and make my plug wires. My pops dropped it in cause he needed the picker. Put a new throwout bearing in the trans and changed lube, its ready to go back in. I have a few days in the fuel system that needs to be finished and then the 2 MSD boxes, A1000 fuel pump and the Aeromotive pump controller have to be wired up. Then all the boost signal lines. I am hesitant to run it until I can purchase a Innovative afr/wideband setup.
Just need it to cool down a bit so I can get back to tinkering with it.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905402
08/07/11 06:49 AM
08/07/11 06:49 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Bummer the heat is keepin you from it. Cant wait til it cools off so I can see some more updates
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: 69B3GT] #905403
08/08/11 01:23 AM
08/08/11 01:23 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
19 days straight of 100+ temps and said to continue through August and into Sept.. It suks! GLOBAL WARMING???
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905404
08/08/11 12:00 PM
08/08/11 12:00 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Only 19 days? DFW is approaching 40 consecutive days over 100 degrees.
I haven't made any progress on the hot rod either.
- Stu Harmon
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: feets] #905405
09/02/11 05:38 PM
09/02/11 05:38 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
I did get the last major piece of the puzzle,
http://cgi.ebay.com/ebaymotors/AEM-30-41...=item3a699f549a
Now if the darn heat would go away!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905406
09/30/11 03:54 PM
09/30/11 03:54 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Ok,
engine is in. Real tight with the plugs/wires installed. I am wondering how well this wrap is gonna work or if I should get something to cover the wires.
Gotta get the trans cleaned up and repainted before I put it back in. Here is a few pick of the progress, not much but something!! I ran out of wrap but the driverside will be easy to wrap on the car.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905407
09/30/11 03:54 PM
09/30/11 03:54 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
47
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905408
09/30/11 03:55 PM
09/30/11 03:55 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
48
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905409
09/30/11 03:56 PM
09/30/11 03:56 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
49
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905410
09/30/11 03:57 PM
09/30/11 03:57 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
50
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905411
10/02/11 08:13 PM
10/02/11 08:13 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Got a little more done today. Alternator has been relocated and fits real good if I might say! Belt lines up good just need to get one about three inches shorter. Need to get the alternator wires out of the factory loom and rerun those to the driverside. Still gotta finish the plug wires since everything is in place. Starting to look pretty good! I have a fan shroud but can't put my hands on it at the moment so the fan will wait. I think the 850 Holley is too big so waiting on a 750 main body then can start the "Hanger 18" mods. Then the worst part, Electronics need to be wired up as well as the fuel pump and fuel lines.
Soooon I hope!
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905412
10/02/11 09:01 PM
10/02/11 09:01 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
51
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905413
10/02/11 09:03 PM
10/02/11 09:03 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
52
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905414
10/04/11 12:23 AM
10/04/11 12:23 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
I just got a wrench thrown into my plans.......... My good friend was over today and seen my 4 speed sitting on my roll-around.
He said,
You wanna 727 with reverse manual and a small stall???
I know its probably the right thing to install the 727.
But I sold my pristine auto console and shifter a while back to a guy in California and I have this huge 4 speed hump in my floor(was like that when I got it)..
NOW WHAT DO I DO?????????????
Any opinions??? I know it would be better for the turbo as far as keeping it under LOAD!
ARRRGGG!
