Re: 68 383 Formula S now 411" B with Borg/Warner S480
[Re: CUUDAK]
#905260
01/16/11 12:22 PM
01/16/11 12:22 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Sounds like a good build! However, if you could use the room, 5" DP is wayyyy over kill. 4" is plenty. EDIT: I read your link to get the info I was questioning...
[Re: TheOtherDodge]
#905261
01/16/11 03:40 PM
01/16/11 03:40 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
Yeah, I had questioned why on TTF and I was told that if it was meant to have a 4" the flange would have been 4"... Before all is said and done I more than likely will need to convert from the Holley to MSII. Its a real PITA to tune a blow-thru carb. This was supposed to be a budget build. Already over $5000.. If it weren't for the total suspension rebuild due to the disc brake conversion I would be well under the budget. Buuuut, I prefer a good foundation for what I expect from this setup and want to be able to stop! LoL! When I get it running I plan on taking it out to Sealy and see what she does.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: CUUDAK]
#905262
01/17/11 03:28 PM
01/17/11 03:28 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
When building your manifolds keep the log no larger than necessary. When a small primary dumps into the big pipe velocity will drop. A 3" log may be a bit large.
[Re: TheOtherDodge]
#905264
01/18/11 12:14 AM
01/18/11 12:14 AM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
I disagree, I logged back pressure and seen a near 1:1 ratio with my s475/5inch down pipe.... It's all about pressure differential....
[Re: Wilde Racing]
#905265
01/18/11 01:44 AM
01/18/11 01:44 AM
CUUDAK
HEMPSTEAD TX
This is basically what I was told,
All else being equal, _The amount of work that can be done across an exhaust turbine is determined by the pressure differential at the inlet and outlet_ (in English, raise the turbo inlet pressure, lower the outlet pressure, or both, and you make more power) Pressure is heat, heat is pressure.
Raising the inlet pressure is possible, but tough. Lowering the outlet pressure is easy - just bolt on a bigger, free flowing exhaust. I've seen a couple of posts from people who added aftermarket exhausts, who report "my turbo spools up faster now" Well, that's because by lowering the outlet pressure, you increased the pressure differential, and now the exhaust gas can expand more, and do more work. That increased work pushes harder on your turbo, and it spools up faster. You should also see less boost drop at redline, because if an exhaust system is flow-limited, once you pass the flow limit of the system, any additional gasses you try and force through it only raise the outlet pressure. Higher outlet pressure, lower pressure differential, less work, less boost.
[Note that the compressor side comes into play here too - that's another story]
[Re: CUUDAK]
#905268
01/19/11 11:04 PM
01/19/11 11:04 PM
CUUDAK
HEMPSTEAD TX
Worked on it a little today. Here is the T6 flange setup with 2 threes merging,
[Re: CUUDAK]
#905270
01/22/11 11:50 PM
01/22/11 11:50 PM
CUUDAK
HEMPSTEAD TX
Got a half a day in these. They ain't very pretty but I think they will do the job. I was concerned about the top pipes angle into the log but it is what it is!! That very first hole may be an issue too. But it will all fit under the stock hood, even with the 5" DP. I can get to all the header nuts and sparkplugs either from the bottom or through holes in the apron. Still need a bit more time in the square end at the flange.
Anyhow here are a few pics of the pipeline facility!!
[Re: CUUDAK]
#905274
01/24/11 05:53 PM
01/24/11 05:53 PM
feets
Senior Management
Senior Management
Irving, TX
My logs were made from the same stuff and I have issues with cracks.
