what would you guess for HP on this 383 setup? #90504
07/18/08 09:08 PM
07/18/08 09:08 PM
delivering your oil
nutso suave Offline OP
delivering your oil
i am looking at buying a car that comes with this engine set up. what horsepower rating would you estimate? is this cam a low end grunter or a high end screamer? thanks.
1970 383, 906 Heads, Edelbrock 800 CFM Carb, Edelbrock RPM Dual Plane Intake, Hooker Fender Well Headers, 11-1 Compression, Purple Shaft Cam 292 Duration 509 Lift, Pro Comp Roller Rockers, and Electronic Ignition.
Re: what would you guess for HP on this 383 setup? [Re: nutso suave] #90505
07/18/08 10:09 PM
07/18/08 10:09 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Here's my official W.A.G. If it has a "real" 11:1 compression ratio,that cam will work in a 383.It will be very rough at idle and need a 3500-3800 stall speed and a fairly steep gear. Depending on what level of prep/modification work has been done to the heads,it could make somewhere in the 420-430 H.P. neighborhood with a 6300-6500 r.p.m. peak. Lots of other variables will effect the power output too.
Re: what would you guess for HP on this 383 setup? [Re: 67_Satellite] #90506
07/18/08 10:36 PM
07/18/08 10:36 PM
nope. you can make 420-430hp with way less camshaft. i would guess
somewhere between 470-490hp at 6500rpm.
Re: what would you guess for HP on this 383 setup? #90507
07/18/08 11:38 PM
07/18/08 11:38 PM
delivering your oil
delivering your oil
it has a weak stall setting on the torque converter at 2500, and has a 3.91 differential ratio.
thanks!
