Viper Brakes on and A Body - Spindle Question #904613
01/14/11 05:45 PM
01/14/11 05:45 PM
Raleigh, NC
John426 Offline OP
super gas
John426  Offline OP
super gas
Raleigh, NC
I'm doing the Viper Caliper conversion on my Dart using Andyf's kit (very cool piece, btw!). I scored a set of used viper calipers and went to install the whole shebang and the kit calls for 73-76 A Body DRUM spindles! I don't have any and was wondering if the 73-76 A Body Drum spindle is the same as the B Body spindle? I suspect it uses the large upper ball joint and was wondering about the inner bearing race size - is that the only difference?
Anybody know? I have a lot of B Body drum brake spindles (from doing disc brake upgrades!!) or does anybody have a set of A Body 73-76 Drum spondles they wanna trade or ???? (smile).
Thanks!!
Moparts Rocks!!
Re: Viper Brakes on and A Body - Spindle Question [Re: John426] #904614
01/14/11 06:08 PM
01/14/11 06:08 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The only difference between '73-'76 A drum knuckles and B/E drum knuckles is the diameter of the seal surface and inner bearing ID.
I make a spindle sleeve/seal kit that adapts the larger inner bearing to the smaller spindle OD.
Re: Viper Brakes on and A Body - Spindle Question [Re: DoctorDiff] #904615
01/14/11 11:49 PM
01/14/11 11:49 PM
Raleigh, NC
John426 Offline OP
super gas
John426  Offline OP
super gas
Raleigh, NC
Cass - Thanks for the info. I've used your inner bearing adapters before to use the later model rotors on the 70-71 E Body disk brake spindles. HUGE difference in price between the 70-71 rotor and the 73-74 rotor!
OK, So I can use one of my B Body drum brake spindles, your inner bearing adapter and the late model rotor. That works for me!!
Thanks!
