orange box #90443
07/18/08 04:52 PM
07/18/08 04:52 PM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
burned one out the other day
I was wiring a sterio and left on the key for about an hour this orange box came with kit i got from Summit the cheaper one i think they called it proform,is this unusual or did i receive just punishment for leaving the key in on possition for about an hour, dint think to use the accessory side of the switch was only gonna be a minute anyways. i have heard of burning the points up like this but this is electronic
Re: orange box [Re: mikepar] #90444
07/18/08 06:25 PM
07/18/08 06:25 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Well not sure about how you burned yours up but quite a few people myself included have had problems with the orange box, on one of my cars I put a 20 year old silver box back in and so far no problems. I would suggest a silver or getting a FBO setup but the FBO is a kit not just the box. Good luck.
Re: orange box [Re: 68Fastback] #90445
07/18/08 06:37 PM
07/18/08 06:37 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
I've had my share of orange boxes go bad - that's the main reason why I went with the MSD.
'71 SSP - SOLD!
Re: orange box [Re: mikepar] #90446
07/18/08 06:45 PM
07/18/08 06:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think the proform's are cheaper off shore knock offs. some of them are blue and can be bought for $10-$15. i've got one i keep for a spare in the trunk. i've never popped a ecu and have used them since 1973. i do believe that all ecu's are susceptible to failing due to wiring glitches, shorts, etc.
Re: orange box [Re: mikepar] #90447
07/18/08 07:08 PM
07/18/08 07:08 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Dunno what year or model you own, but my '72 Barracuda has a standoff bracket for mounting on the firewall. Never a problem with the orange boxes.
My '72 Monaco wagon had the ECU mounted right on the firewall, and the "potting material" or insulating jelly melted and ran down the firewall.
Those big honking power transistors in the ECUs get hot. The 'cuda was a later build date than the wagon. Chrysler had to pinch pennies to compete, so that gives you a good clue as to why they went with the standoff even with the 15 cent sheet metal standoff.
Re: orange box [Re: mikepar] #90448
07/19/08 12:10 AM
07/19/08 12:10 AM
no you aren't being punished.it's just a(unfortunate) coincidence, as mentioned they have reliability issues.
Re: orange box [Re: RapidRobert] #90449
07/19/08 10:42 AM
07/19/08 10:42 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
MSD boxes are not that reliable, I have two sitting here waiting to be sent back to MSD for repair.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
