The ring gaps vary with manufacturer I think. The values are determined by a 'factor' which is multiplied by inches of bore size. X amount per inch of bore. X will be a bigger number for forced induction or nitrous use= bigger gap. On my 4.030 bore small block I think the top gaps on standard iron rings ended up around .015" but that's a wild guess my paperwork is not in front of me.
I do remember the first time I hand filed rings I misunderstood the directions and ended up with a proper gap for a top fuel blown application! Lucky for me I was able to order a set of just top rings from the manufacturer.
There are different opinions about the second ring gap- I would go with the factory recommendation unless you know something they don't.
Also remember too big might burn a little oil but too small can seize up and possibly rip the top of the piston off, especially with detonation or hyper pistons.
Also remember Im just some guy, not a pro or expert
Good luck!
