71 rr power stering going full ast to the left #90439
07/18/08 04:43 PM
07/18/08 04:43 PM
Anonymous OP
Anonymous OP
new box had a leaking o ring took the adater off were the high preesure ond return lines hook up change all the orings now it goes all the way to the left with out touching the wheel can it be adjusted out thanks
Re: 71 rr power stering going full ast to the left #90440
07/18/08 04:52 PM
07/18/08 04:52 PM
Andrewh Offline
Andrewh  Offline
The piece that has both hoses going to the gear box needs to be moved towards the firewall or away from the firewall to correct it.
You have to loosen it a little and tap it forward or back.
The car needs to be in the air to do it.
Re: 71 rr power stering going full ast to the left [Re: Andrewh] #90441
07/18/08 05:35 PM
07/18/08 05:35 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Just loosen enough to tap with a brass hammer but still keep it snug. There are little O'rings under it and they will come out of place if you loosen too much.
Re: 71 rr power stering going full ast to the left [Re: MoparforLife] #90442
07/18/08 07:09 PM
07/18/08 07:09 PM
Anonymous OP
Anonymous OP
thanks guys
