Slipped 440 harmonic balancer ? #903910
01/13/11 06:39 PM
01/13/11 06:39 PM
IL . usa
cjs69mope Offline OP
IL . usa
Has anybody seen a steel crank 440 harmonic balancer slip the outer ring?
My friend has a 71 440 in his 86 dodge ram , we can not time the engine with the timming light. The engine timming mark looks so far advanced that if you turn the distributor to get the timming marks to line up the engine starts running very bad and back fires out the exhaust .
I suspect the outer ring has slipped and now i can only time the engine by ear and seat of the paints shade tree style . Not what i would like!
Was wondering if this happens to thease balancers ?
1969 Dodge Charger 1969 Dodge Superbee
Re: Slipped 440 harmonic balancer ? [Re: cjs69mope] #903911
01/13/11 06:56 PM
01/13/11 06:56 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Yes.
Re: Slipped 440 harmonic balancer ? [Re: Chilort] #903912
01/13/11 07:17 PM
01/13/11 07:17 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Yes they can slip.
You can check with a TDC tool to verify if that is the problem.
Re: Slipped 440 harmonic balancer ? [Re: cjs69mope] #903913
01/13/11 07:57 PM
01/13/11 07:57 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Either the one I had was wrong or it had slipped about 70 degrees. The marks on in the picture shows the difference. I put a new balancer now the marks line up as should.
Re: Slipped 440 harmonic balancer ? [Re: ProStDodge] #903914
01/13/11 08:05 PM
01/13/11 08:05 PM
Very rare. Yes check it w the tool (it's cheap & you'll need it eventually. I'd pull the plugs and pass valve cover & get "rockover" on #6 valves & that will put the balancer marks within a degree or 2 of TDC & that tells you it nor the tim chain have not slipped. You get "rockover" by turning the crank till both #6 (in/ex) valves are (1) at the same height and (2) at that point you move the crank back & forth a slight bit and both valves move then set em back even. I suspect the dist is timed wrong EDIT using rockover on #6 as described will put the marks at TDC on #1 compression whereas rockover on #1 valves would also put the balancer marks at TDC but you'd be on #6 compression so use #6 rockover then the dist is ready to b set w rotor to #1 plug terminal
Re: Slipped 440 harmonic balancer ? [Re: RapidRobert] #903915
01/13/11 09:13 PM
01/13/11 09:13 PM
IL . usa
IL . usa
How could it be the distributor if the car runs fine when turning it?
Re: Slipped 440 harmonic balancer ? [Re: cjs69mope] #903916
01/13/11 09:45 PM
01/13/11 09:45 PM
(1) tooth off on the inter gear
Re: Slipped 440 harmonic balancer ? [Re: cjs69mope] #903917
01/13/11 09:47 PM
01/13/11 09:47 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Does this engine have the original Nyla-gear timing set in it by chance? when mine (timing set) gave up it would not run! timing skipped way off! Do what Robert suggested first than check out the timing set if it's unknown? The damper can slip but rare
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Slipped 440 harmonic balancer ? [Re: R70RUNNER] #903918
01/13/11 10:43 PM
01/13/11 10:43 PM
Pull the plugs and do a compression test on any 1 cyl. If in your normal range that'll tell you in minutes that the tim chain has not jumped and the prob is in the inter gear clocking or the dampener has indeed slipped
