Lower Control Arm Lengths #903864
01/13/11 06:01 PM
01/13/11 06:01 PM
Tracy CA
rabid scott Offline OP
"You're Where?"
"You're Where?"
Tracy CA
I've got several sets of control arms from past project and parts cars and I'm trying to get them sorted between the A-body and B-body arms.
Is there a measurement for these, maybe from the torsion bar center to the ball joint mount?
I tried searching, but came up empty handed. Thanks guys!!
Re: Lower Control Arm Lengths [Re: rabid scott] #903865
01/13/11 06:11 PM
01/13/11 06:11 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
Look for the letters on the front flat side of the LCA's.
Scrape away the dirt and grime, and or surface rust to look for the letters.
RW BJ would be B & E body
VL would be the A body cars.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Lower Control Arm Lengths [Re: rabid scott] #903866
01/13/11 06:11 PM
01/13/11 06:11 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
73-76 A-body
Re: Lower Control Arm Lengths [Re: rabid scott] #903867
01/13/11 06:13 PM
01/13/11 06:13 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The easiest way to tell them apart is to look at the bottom edge. The A body arms are flat across the bottom, the B body arms are curved. The pivot shafts are "stepped" on B body, the A body pivots are tapered from threads to the bushing.
Finally, the B body arms are actually SHORTER from ball joint to pivot shaft... kinda wierd.
