Re: need 440 6pk metal base A/C ,repops?
[Re: meepmeep70]
#903567
01/13/11 02:24 PM
01/13/11 02:24 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Darren,...if you'd prefer, the fiberglass ones offered aren't really that bad, I've run a few in the past,...I'd only run the base, and a metal lid incase there was ever a fire,..I've never had any issuse with then, they held up fine to years of underhood engine heat, take the time to finish it out, and paint it, most people never notice...YearOne has several listings, and Moparts member "Paint it Black" runs Hybredsolutions or something to that effect, making repro fiberglass air cleaners
Mike
[Re: meepmeep70]
#903570
01/13/11 03:52 PM
01/13/11 03:52 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
check with Ben Snobars NW Performance....
I am truckless..
[Re: DaytonaTurbo]
#903572
01/13/11 04:01 PM
01/13/11 04:01 PM
Posts: 3,530 Lansing, MI
70gtx440dana
Lansing, MI
Check out Ebay item 370473955785. This kit has everything you need including air cleaner, filter, carb gaskets, carb studs etc. for $380 opening bid. Ready to bolt on.
Edit: Wow the Summit deal above is better!!!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
