What grade fuel do you use in your 5.7 Hemi? #903498
01/13/11 11:35 AM
01/13/11 11:35 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I have spoken to a few local folks who have the 5.7 Hemi engine and they all recommend putting in the highest grade fuel available. Here in Ca. it's 91 octane only.
I looked though the owners manual on my 2003 Dodge truck and did not any mention of using 91+ fuel.
Anyone got any opinions on if 91 will do better for overall performance than 87 will or is this just a personal preferance??
Stu
Re: What grade fuel do you use in your 5.7 Hemi? [Re: MidPenMopar] #903499
01/13/11 11:43 AM
01/13/11 11:43 AM
33950
67Monaco Offline
67Monaco  Offline
33950
I run 93 in mine but I also run a tune and anything less pings like hell.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: 67Monaco] #903500
01/13/11 11:45 AM
01/13/11 11:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
before I hit my magnum w/ the programer I ran 87 w/ no problems, but I hit it w/ a 93 tune so I have to use 93. I guess I could always swap it back to the 87 until I go to the track.....
Coming soon!!!!
Re: What grade fuel do you use in your 5.7 Hemi? [Re: MidPenMopar] #903501
01/13/11 11:48 AM
01/13/11 11:48 AM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
you should double check your manual because I had a 2003 ram 2500 with the hemi and it did recommend 91 or above for fuel. I did some research back then and found that very few engines these days do need high octane fuel. The hemi falls into that category because it has high compression. I always ran mine on on 91 or above and never had any engine issues.........rust, however was a different story.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: fireeng] #903502
01/13/11 11:53 AM
01/13/11 11:53 AM
you should double check your manual because I had a 2003 ram 2500 with the hemi and it did recommend 91 or above for fuel..
Ok maybe i missed it where is said 91 or better? I have been know to make mistakes once in awhile.
It's only like $0.20 a gallon more then 87 so i will start filling the tank with super from now on.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: MidPenMopar] #903503
01/13/11 12:05 PM
01/13/11 12:05 PM
Ohio
john55 Offline
john55  Offline
Ohio
Stu, we leased an 05 Durango with a 5.7, we always used regular, always ran fine, no problems for 48k miles
The Plymouth Win You Over Beat Goes On
Re: What grade fuel do you use in your 5.7 Hemi? [Re: john55] #903504
01/13/11 12:21 PM
01/13/11 12:21 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
I looked in my 05 owners manual and it said "recomend 89" , I just looked in my 07's and it says the same thing...have always ran 87 with no problems ever...if towing I'll use 91
You Thinking It's So Doesn't Make It a Fact
Re: What grade fuel do you use in your 5.7 Hemi? [Re: 9SecRoadRunner] #903505
01/13/11 12:34 PM
01/13/11 12:34 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
87 oct. for me I have 90k on my 2004.
If I tow I use 89...never pings. never
Re: What grade fuel do you use in your 5.7 Hemi? [Re: 70blackfish] #903506
01/13/11 01:02 PM
01/13/11 01:02 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
You are probably fine, but I believe they do better with a little more octane. I did have an 04 hemi truck and I always ran 87, but if I could go back in time I would probably have run atleast 89.
I only say that because of what I have noticed with my 2010 challenger. I run 93 now because of the tune, but I ran both 87 and 89 with the factory tune and data logging showed me quite a bit of knock on hard runs. I will also say that I could not hear it so just basing it off of sound doesn't mean it isn't happening or trying to happen.
just my .02
Re: What grade fuel do you use in your 5.7 Hemi? [Re: RonP] #903507
01/13/11 01:15 PM
01/13/11 01:15 PM
MA
Mass_Mopar Offline
Mass_Mopar  Offline
MA
They recommend 89 but we run 87 in both the 04 Hemi Ram and the 05 300C. We don't beat on them and run the stock tunes. I've never heard either knock, I've also never raced either one.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: Mass_Mopar] #903508
01/13/11 03:57 PM
01/13/11 03:57 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have 94,000 on a 2007 and I have run 87 octane almost exclusively. I have tried 89 and 91, but I couldnt tell any difference.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: MidPenMopar] #903509
01/13/11 04:18 PM
01/13/11 04:18 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Stu, check the OM again as its in there some where. On mine, 89 as recommended in OM, 91 with diablo tune(W/CAI&180* T-stat),D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: Kern Dog] #903510
01/13/11 08:11 PM
01/13/11 08:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
We use 87 in our 2005 hemi.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: Challenger 1] #903511
01/13/11 08:33 PM
01/13/11 08:33 PM
Good info!! Thanks guys!!
Re: What grade fuel do you use in your 5.7 Hemi? [Re: MidPenMopar] #903512
01/13/11 08:51 PM
01/13/11 08:51 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I run 89 in my 2010 Hemi Ram, no issues!
1972 Road Runner
1988 Shelby CSX-T
Re: What grade fuel do you use in your 5.7 Hemi? [Re: racerx20] #903513
01/13/11 09:15 PM
01/13/11 09:15 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
The California 87 swill here Stu, for Rene's magnum.... I've run 89 and I can't tell a diff
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: What grade fuel do you use in your 5.7 Hemi? [Re: R70RUNNER] #903514
01/13/11 09:32 PM
01/13/11 09:32 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Mid grade as recommended in the 06 Daytona
Premium (if you can call it that out here) 91 in the 6 speed.
Re: What grade fuel do you use in your 5.7 Hemi? [Re: R70RUNNER] #903515
01/13/11 09:33 PM
01/13/11 09:33 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
I have a 09 Charger, owners manual says 87 is recommended, 89 is ok but do not run higher than 89
Re: What grade fuel do you use in your 5.7 Hemi? [Re: mopardad] #903516
01/13/11 09:45 PM
01/13/11 09:45 PM
Why not higher than 89?? Just because it's a waste of $$$??
Re: What grade fuel do you use in your 5.7 Hemi? [Re: mopardad] #903517
01/13/11 10:42 PM
01/13/11 10:42 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
I have an 07 300C and an 07 Charger R/T, both have the 5.7L Hemi. The manual states 89 octane. When 89 isn't available use 87, and it says premium gas is NOT recomended.
