What type finish would be toughest for rearend housing?
#903134
01/12/11 10:47 PM
01/12/11 10:47 PM
Posts: 1,070 Newton, KS
70B5Cuda
Newton, KS
I am looking for a tough finish for the axle/rearend housing? What would be toughest-enamel/urethane/epoxy?
And how would the toughest compare to a powdercoat?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: What type finish would be toughest for rearend housing?
[Re: 70B5Cuda]
#903135
01/12/11 11:03 PM
01/12/11 11:03 PM
Posts: 15,487 Florida
scratchnfotraction
I just sand blasted and used rustoleum gloss black with a couple rattle cans of color myself,daily driveing and a floor jack is about as hard as I get on a rear axle now days,just in it for the looks but powder coating is tuff,but harder to touch up chips and nicks 4x4? I have seen the sprayed bed liner on axle housings before,that was different and look some what good,the rest of the rig had it in the floor/cab/bed
[Re: scratchnfotraction]
#903137
01/12/11 11:09 PM
01/12/11 11:09 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
That Rustoluem is some pretty tough stuff,bout like the old chassis black.
[Re: 70RT Charger]
#903139
01/12/11 11:19 PM
01/12/11 11:19 PM
scratchnfotraction
i did most of the truck with 1 gallon of it,frame/axle/bottom side front clip/under hood/inside cab/jambs hood got rustoleum satin black body got 2k primer and its gets lemon yellow 2 stage paint herculiner for the bed and widen tubs,with 1 case/24 cans of mar-hyde sound deadner/under coating should be tuff enuff for what i do
[Re: 70B5Cuda]
#903140
01/13/11 12:17 AM
01/13/11 12:17 AM
Posts: 53 Jensen Beach, Florida
pressureangle
Few people know that Powdercoating was first developed by Ford Motor Company, for use on suspension/undercarriage components as a coating that would endure. Hard to beat something that was created with intent.
Tell your powdercoater you want it applied about twice as thick as they usually do. It's not paint.
Why do I torture myself so?
[Re: None2Slow]
#903143
01/13/11 08:27 AM
01/13/11 08:27 AM
Posts: 18,160 Mass
DAYCLONA
Mass
The more shine to the paint, the less durable it is. At least according to my local paint supply. Went semi gloss underhood for me.
[Re: DAYCLONA]
#903144
01/13/11 09:49 AM
01/13/11 09:49 AM
70B5Cuda
Newton, KS
A local powdercoating company said that metallic colors don't hold up as well as solids so they suggest a clear powdercoat over the color powdercoat..
[Re: 70B5Cuda]
#903146
01/13/11 01:05 PM
01/13/11 01:05 PM
Posts: 22,728 Bitopia
jcc
Bitopia
IMO, on scale 1-10, powder coat being 9, 2 part urethane 7.2, epoxy 6.9 (it chalks?) enamel 4.5. Not sure what your concerns are, but you could for a reasonable cost yellow zinc plate the entire housing , and then do any of the above processes, which would almost completey rule out rusting from paint chips, minor scratches, etc. however the paint processes would require a etching or epoxy primer. Not sure how far you want to go with this.
[Re: jcc]
#903147
01/13/11 01:17 PM
01/13/11 01:17 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
I have to disagree with the above, the thickness of the paint determines how easy it is to chip, not whether if it is glossy or not.
[Re: 70B5Cuda]
#903148
01/13/11 01:18 PM
01/13/11 01:18 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I have used the por-15 gloss black paint cheap and a small starter kit can do the whole rear end , very durable and glossy when done as directions say . the nice thing to is if you want you can brush it on and still hard to tell it was brushed the paint is very self leveling and forgiving .just use a good quality hair brush (works the best .)
1969 Dodge Charger
1969 Dodge Superbee
[Re: 70B5Cuda]
#903150
01/13/11 07:10 PM
01/13/11 07:10 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Mine had surface rust, so I washed it good and brush painted it with rust converter. Then I brush painted it also with polyoluem gloss black. It has looked really good for years. But if you are willing to spend more, I agree with earlier post that Eastwoods chassis black is good stuff.
Facts are stubborn things.
[Re: None2Slow]
#903151
01/13/11 11:16 PM
01/13/11 11:16 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
