Re: does your car have a heater hose valve?
[Re: Andrewh]
#90298
07/18/08 04:05 PM
07/18/08 04:05 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'68 B bodies without A/C don't have a water valve, coolant flows continuously through the heater core and the blend door controls the temperature.
[Re: John_Kunkel]
#90299
07/18/08 04:07 PM
07/18/08 04:07 PM
Posts: 21,854 Kirkland, Washington
Pacnorthcuda
I believe thats the rule for E-bodies too, at least 70's.
[Re: John_Kunkel]
#90300
07/18/08 04:09 PM
07/18/08 04:09 PM
Posts: 6,516 Santa Cruz, California
Lefty
Same for 66 B bodys. That's why I'm getting ready to add one to my Coronet. The heat leaks through the blend door and it's too toasty in the footwell cruising in the summer. ![](/ubbthreads/images/graemlins/weld.gif)
[Re: Lefty]
#90301
07/18/08 04:26 PM
07/18/08 04:26 PM
Pacnorthcuda
I found a simple ball valve at Lowes for the heater hose (that isn't to big and clunky looking)and put it inline so that I can now shut down the flow in the Summer. Its amazing how much more comfortable the interior is on a hot day! Makes a huge difference.
[Re: Andrewh]
#90302
07/18/08 04:29 PM
07/18/08 04:29 PM
Posts: 609 a cornfield near you
BlakDak
Did your car come with a heater hose valve? So far every mopar I have ever owned has one, but I thought I would be sure. Apparently a lot of newer trucks and cars don't. Just curious about 60's and 70's mopar. This is for the painless 5.9 setup.
Year and model would be nice.
Also anyone that did not have one stock so I can get a feel for it.
I am pretty sure unless it had A/C its not going to have a heater control valve.
[Re: Andrewh]
#90304
07/18/08 05:33 PM
07/18/08 05:33 PM
RapidRobert
I am going to add one to my 65 dart,Even with the controls off I'm burning up.
[Re: Pacnorthcuda]
#90306
07/18/08 11:38 PM
07/18/08 11:38 PM
Lefty
I'm going to try and install a vent cable to a valve I got off ePay, I dunno if I can make it work. ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: Lefty]
#90307
07/19/08 12:14 AM
07/19/08 12:14 AM
RapidRobert
after reading these posts I need to check & see if one of my doors/cables is misadjusted. With the levers off I shouldn't be getting this amt of heat inside.
[Re: RapidRobert]
#90308
07/19/08 03:17 PM
07/19/08 03:17 PM
John_Kunkel
Rio Linda, CA
Even if the cable is properly adjusted it's not uncommon for a deteriorated rubber seal on the blend door to allow heated air to enter the cabin.
[Re: John_Kunkel]
#90309
07/19/08 05:27 PM
07/19/08 05:27 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
OK, not to hijack....still on topic, so bear with me on this one!!! The heater core has two hoses. I assume one is supply and the other is return. If I were to put a cut-off valve on the supply hose do I have to have a bypass between the supply side hose and the return side hose? Effectivly bypassing the heater core. (if that makes any sense) Thanks ![](/ubbthreads/images/graemlins/beer.gif) Frank
