another camquest post
#902771
01/12/11 03:26 PM
01/12/11 03:26 PM
Posts: 2,578 sweden
1Fast340
sweden
i have seen some post about camquest and i can now oficialy say i doubt it after testing it and not alitle from what i saw i feel that its waaaaaaaaaaaaaaaaaaaaay out there.. noway my missmatched twinscrewed stockstroke 340 is going to make 700hp@6500rpm and over 700ftlb@2500rpm at 8psi of boost lower the numbers atleast 100 and the torque at a higher rpm and i may believe it.. nice program but would be nice if it was alitle closer to reality..
Re: another camquest post
[Re: MR_P_BODY]
#902775
01/12/11 04:17 PM
01/12/11 04:17 PM
Posts: 2,578 sweden
1Fast340
sweden
What is your reasoning that its WAY off... any dyno data or track numbers...just asking
no data on my motor yet i just cant see a engine like what i have making 700hp and 700lbft from the pile of parts i have started assembling especialy since i dont have anything even close to a real blower cam and knowing that a friends 383 that was built as a blower engine with all the right parts and having more cubes made 599 hp at the dyno and that was pretty much all it could make
what kind of power would you guestimate from a stockstroke 340? edelbrockheads that are wellported 9.7:1compresion on E-85 solidroller made for N/A with 242/248@.050 .570/.576 lift with a 110lobecenterline with a dominator on top of a lysholm 3.3liter twinscrew (very simmiliar to a 3.3liter whipple) 1 7/8"primary headers i have my doubts about how long the block will last:(
nevermind the old poor dominator i have a much nicer one to put on the engine when its done
[Re: emarine01]
#902777
01/12/11 05:36 PM
01/12/11 05:36 PM
Posts: 2,578 sweden
1Fast340
sweden
Hey did ya ever think about cutting the old domminator in half... ..... only kidding
now that you say it,may need to get another one so i can have homebuilt splitdominators if i ever build another smallblock without a poweradder who knows what the future has for me LOL
and forgot to add in my last post that i understand that calculators are very dependent on correct userinput,and i put in everything as close to right as i can
[Re: 1Fast340]
#902778
01/12/11 05:48 PM
01/12/11 05:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
no data on my motor yet i just cant see a engine like what i have making 700hp and 700lbft from the pile of parts i have started assembling especialy since i dont have anything even close to a real blower cam and knowing that a friends 383 that was built as a blower engine with all the right parts and having more cubes made 599 hp at the dyno and that was pretty much all it could make what kind of power would you guestimate from a stockstroke 340? edelbrockheads that are wellported 9.7:1compresion on E-85 solidroller made for N/A with 242/248@.050 .570/.576 lift with a 110lobecenterline with a dominator on top of a lysholm 3.3liter twinscrew (very simmiliar to a 3.3liter whipple) 1 7/8"primary headers i have my doubts about how long the block will last:( nevermind the old poor dominator i have a much nicer one to put on the engine when its done
Big thing is that 8 pounds of boost... 8 psi is 8 psi weather you have junk parts or not... most guys on the street dont go anywhere near 8 psi... plus your starting with some pretty high compression then adding 8 psi
[Re: 1Fast340]
#902779
01/12/11 06:31 PM
01/12/11 06:31 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I agree. The results are SO FAR OFF its not funny. I'd hate to even mention what the results are for fear of getting my ass kicked by something with much lower but "true" dyno numbers.
I input the data for my 526 RB stroker with 10.4 cr, Indy EZ1's, 2" headers, SP Indy intake, 900 cfm carb and Lunati roller cam.
CamQuest results are 760 HP @ 6500, 710 Ft/lb tq @ 4500.
All the same data in Desktop Dyno yeilds 515 HP @ 5000, 612 ft/lb @ 4000.
Who ya gonna believe ?!?!?!?
These are toys but they both indicate one thing, in my application the Lunati roller cams outperform the Comps.
[Re: Stanton]
#902780
01/12/11 07:37 PM
01/12/11 07:37 PM
MR_P_BODY
I agree that there is a error factor... maybe 10-15 percent.... JMO... but that desk top is WAY off... anyone could screw up big time and still make 515 hp out of 526ci
[Re: Stanton]
#902781
01/12/11 10:32 PM
01/12/11 10:32 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I didn't find the results to be that far off HP wise, but then again I'm not looking over your shoulder verifying your input numbers. A 526 RB making only 515 HP should be suspect. Your combination of parts should be worth at least 1.2HP/CI (630 HP). A roller with ported heads should be closer to 1.3HP/CI (680HP).
ETA: RE Cam Quest, did you make the mistake of not changing the valve size when inputting your head flow numbers?
[Re: Stanton]
#902783
01/13/11 12:17 AM
01/13/11 12:17 AM
MR_P_BODY
Well maybe its Desktop Dyno that's out to lunch. Who knows. I was just thinking the CamQuest results were kinda high. Hey, BONUS if they're closer than Desktop Dyno !!!
If you cant make 1 HP per CI there is something MAJOR wrong... that engine should make 650+ IMO
[Re: emarine01]
#902785
01/13/11 12:46 AM
01/13/11 12:46 AM
MR_P_BODY
I tried inputting the cam specs using sledge's instructions and lost 20 hp from cam quest best cam recommendations ... but it was still 683 @ 6500 Desk top is 647 @ 6800... they are both very good for the ego but not the real deal
I tried doing that and I screwed up (as normal).. but the one cam they suggest is almost a perfect match to what I have... if I use a 1.6 intake rocker which I am planning on
[Re: MR_P_BODY]
#902786
01/13/11 02:22 PM
01/13/11 02:22 PM
Posts: 2,578 sweden
1Fast340
sweden
i can see that i gues i may be in for a big surprise then, my only reference is a lower compression 383sbc with much better heads and alot bigger cam that is ground for the aplication making 600hp at 7PSI on pumpgas compared to my cam that wasnt intended for a blown engine with alot less airflow thru the heads at just alitle more boost with a slightly better supercharger for sure i wont start out at 8pounds of boost will start out alitle lower until i have figured out the whole car when i can make 6pounds of boost work well with my streetcar i will add more boost until the need is satisifed or the block says boom. ofcourse at the track,realy looking forward to maybe have a chance to play alitle in a local headsup class,not that i will ever win anything but fun to be in the game atleast
[Re: Stanton]
#902787
01/14/11 05:26 PM
01/14/11 05:26 PM
Posts: 16,928 NC
440Jim
NC
Post your inputs and outputs. Head flow screen, output screen. I changed mine almost 200 hp by selecting the correct inputs (small tube headers for 2" on 528, std flow intake not high flow, etc.).
[Re: 440Jim]
#902788
01/14/11 05:39 PM
01/14/11 05:39 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
??? I kinda thought that an Indy single plane MW port intake would be a "high flow" and likewise a 2" would be a "large tube" header !!
I'll try it you way.
[Re: emarine01]
#902790
01/14/11 09:02 PM
01/14/11 09:02 PM
Posts: 2,578 sweden
1Fast340
sweden
2 inch headers are for small blocks
2 inch headers are for small blocks in abodys with powersteering
anyone think 700hp is doable from 340cubes at 8pounds of boost at only 6500rpms?
