A torsion bar is round & you put a preload on it to get the spring effect when it twists. The stress from twisting is spread out around the bar & is evenly distributed. When stress from twisting encounters a gouge in the metal, not just a light surface scratch the stress is distributed unevenly & can cause a stress fracture leading to a failure of the bar. That is why when stress releiving something such as a block, all edges & corners are rounded off, so the stress is distributed evenly & it doesn't stop at a point that could cause a fracture.
