71 Cuda Fual Vapor Diagram #902080
01/11/11 02:56 PM
01/11/11 02:56 PM
Roswell, GA - near Atlanta
cloneguy Offline OP
super street
cloneguy  Offline OP
super street
Help!
We're working on a '71 340 Cuda. We've worked on a bunch of '70's and a few '71's but I've never noticed this particular setup.
The fuel tank has 4 nipples coming out the side and in the trunk is a pipe with 5 nipples on the bottom of it.
There is no fuel return tube on this particular car and I don't know if we have all of the pieces or not.
Does anyone have a diagram to share?
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: 71 Cuda Fual Vapor Diagram [Re: cloneguy] #902081
01/11/11 03:08 PM
01/11/11 03:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think it's called ECS, California car and emmissions. The 5th nipple is vented to the front to the valve cover. My 71 is setup with the 440/6 and hemii vapor separater that attaches to the fuel fuel pump up front. System works great, I highly recomend it.
Re: 71 Cuda Fual Vapor Diagram [Re: Challenger 1] #902082
01/11/11 04:46 PM
01/11/11 04:46 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Hey Challenger1. Do you have more detailed pictures of how the lines attach on the passenger side?? Where does the line that goes to the engine compartment connect?? Yours has 3 lines running to the front. What is the 3rd line?? Do you know if the piece in the trunk is available?? Mine is rusted. Thanks!!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 71 Cuda Fual Vapor Diagram [Re: Prodart440] #902083
01/14/11 09:48 PM
01/14/11 09:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sorry It took me so long to post, been working 15 hours a day here lately.
There's a 3/8" line that goes from the sending unit to the front right frame rail for the fuel pump suction.
Then there's a 1/4" return line that also connects to the sending unit and connects up front to the VS on the fuel pump which has the 1/4" return nipple on it.
Then the 3rd line is actually 2 peices, it's the vent line for the fuel tank, connects to the trunk mounted vapor separator and connects to the 3 nipple breather cap in the pass side valve cover on the engine.
Re: 71 Cuda Fual Vapor Diagram [Re: cloneguy] #902084
01/15/11 12:31 PM
01/15/11 12:31 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
