Re: Lokar Kickdown Cable Adjustment
[Re: 72Challenger]
#901898
01/11/11 09:13 AM
01/11/11 09:13 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
Have that cable in 'your' duster too with the 340. Have you tried giving the cable a tiny bit of slack at WOT? Could be it...
DUDE! How the heck are ya? How's the Duster doing these days? Any new pics or videos you can share with me? Damn I miss that car...
I have a Lokar setup in my Demon too, but I never let the tranny auto-shift, so I've never paid much attention to it in there. My son's RR is a daily driver and shifting at 3500 all the time is becoming a pain. I'll try and take some pressure away from it to see if the shift points drop. Anyone else?
Hans -- send me some pics and/or vids of the ol' Duster when you get a chance. PM me.
THANKS!
[Re: Hotwheelsjr]
#901902
01/11/11 02:23 PM
01/11/11 02:23 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
Thanks all -- and although I agree the Bouchillon one is superior to the Lokar, he already has the Lokar and can't shell out $130+ for the Bouchillon right now. I've thought about it numerous times, but money winds up getting spent on needs rather than wants.
problem with the lokar , from reading posts , is it's a generic setup and needs to be adjusted to work properly in a mopar application , the ratio of the throttle movement to the arm on the trans is not correct , takes trial and error drilling holes and moving the cable pin , which way and how much ????
[Re: 71Plym]
#901905
01/12/11 02:16 AM
01/12/11 02:16 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Adjusting for slack will only solve your problem at partial throttle. You will ALSO lose your high rpm upshift.
To have both an earlier upshift at partial throttle AND a max rpm shift at WOT. You need to shorten the throttle lever on the transmission. Basically you drill another hole inboard on the throttle lever.
A shorter lever will give you more action or a bigger sweep for the same amount of cable travel.
[Re: Magnum]
#901906
01/12/11 05:35 AM
01/12/11 05:35 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Tryed the re-adjusting already You've got a PM
[Re: 72Challenger]
#901907
01/12/11 09:19 AM
01/12/11 09:19 AM
Hotwheelsjr
You've got a PM
Yes -- I backed it off some and it's better but not totally fixed. Trial and error...or $140 for the Bouchillon.
[Re: Hotwheelsjr]
#901908
01/12/11 01:33 PM
01/12/11 01:33 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
You've got a PM
Have it on my 383. Backed it off a bit and it shifts exactly where I like it. Granny-driving it will go in to 3rd at a low RPM. Shifts on it's own at WOT around 4900 RPM's. I manually shift it a lot anyway. At WOT I usually manually shift at 5800 RPM's. Tires spin some, real firm shift, so it has plenty of pressure. Been driving it this way for years. Still shifts great.
Changed tranny fluid recently. Fluid looked really good even for being in there a few years.
[Re: DANA60]
#901913
01/12/11 09:57 PM
01/12/11 09:57 PM
Posts: 643 southern conn
1969gtx
southern conn
if you move the pivit point closer to the center it will move slower so it will not apply as quick on light throttle
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
