Hughes rockers on Victor heads. #901281
01/10/11 05:28 PM
01/10/11 05:28 PM
Canada/USA
ragingram Offline OP
Canada/USA
I've read a lot about different problems the Victors heads have had with push rod clearances.
Have the Hughes rockers fixed this problem? On their website they say to have a .600 offset.
Anyone know what the RPM limit is of these rockers before moving to the T&D's
Just wondering what problems i'll run into before i decide to purchase a set of heads.
Thank you
Re: Hughes rockers on Victor heads. [Re: ragingram] #901282
01/10/11 05:41 PM
01/10/11 05:41 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
you will have to clearance a little bit on head where push rod goes through if your using 1.6 ratio, but i am running Hughes stuff without any problem with my RB and it see's 7300
Re: Hughes rockers on Victor heads. [Re: mistress] #901283
01/10/11 07:12 PM
01/10/11 07:12 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
I used Harland Sharps .650 offset on mine and needed very little grinding. I also see T&D's use a .650 offset on theres also.
