Best $20.00 I have spent #90094
07/18/08 12:14 AM
07/18/08 12:14 AM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline OP
I was having problems with leaky oil filters on my dual remote setup. I have tried Purolator, Mopar, Fram and System1 but they all seemed to leak a little bit. I just bought 2 Napa Gold #1773 and no leaks at all. I highly recommend Napa/Wix filters. They are all that I will ever buy.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Best $20.00 I have spent [Re: Blown_Hemi] #90095
07/18/08 12:27 AM
07/18/08 12:27 AM
that's good to hear.I have a single remote filter setup that I'm getting ready to use & there's a girl at the napa that I am trying to hustle so I'm all set.
Re: Best $20.00 I have spent [Re: Blown_Hemi] #90096
07/18/08 01:14 AM
07/18/08 01:14 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Thats the filters I use also. NAPA gold. I get a pretty good discount from work so that helps.
Re: Best $20.00 I have spent [Re: Posest] #90097
07/18/08 03:08 AM
07/18/08 03:08 AM
I forgot to mention that the 1773 filters are about an inch or so longer than the standard 1515 filters. They take a quart of oil to fill them before installing.
Re: Best $20.00 I have spent [Re: Blown_Hemi] #90098
07/18/08 11:45 AM
07/18/08 11:45 AM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
i use all amsoil now. good for 15,000 mile or one year
Re: Best $20.00 I have spent [Re: wildfish72] #90099
07/18/08 01:03 PM
07/18/08 01:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Some people believe anything.
Re: Best $20.00 I have spent [Re: MoparforLife] #90100
07/19/08 01:13 PM
07/19/08 01:13 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
well ive gone 20,000 last year and then amsoil payed to have my oil analised and it was still holding up , but now i go 15,000 mile because i run my truck pretty hard sometimes. you can believe what ever you want , but ive done it a few times already , best $65 for a oil changed ive ever spent. check out amsoil
Re: Best $20.00 I have spent [Re: wildfish72] #90101
07/19/08 01:50 PM
07/19/08 01:50 PM
Upper Midwest
Upper Midwest
You must NEVER drive off the IDEAL driving conditions. I don't drive in near ideal conditions, Hot summers, cold (no freezing) freezing winters and everything in between, dusty gravel roads to prairie field roads. Hell I can still change oil and filter 4 times for 65 bucks and know I have good clean oil oil not some manufactured substitute. To each their own. That is why there are so many companies.
Re: Best $20.00 I have spent [Re: MoparforLife] #90102
07/19/08 01:57 PM
07/19/08 01:57 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I don't know, all the new BMW cars are running synthetics with a 12,000 mile change interval. It must be OK at least on a brand new engine with minimal blow by. Having said that I still feel more comfortable changing my dinosaur oil every 5000 miles
Re: Best $20.00 I have spent [Re: MoparforLife] #90103
07/19/08 02:02 PM
07/19/08 02:02 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
i really cant see you spending 16.25 each oil change
Re: Best $20.00 I have spent [Re: dmerc] #90104
07/19/08 02:04 PM
07/19/08 02:04 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
thats totaly fine , i was the same way 5,000 miles was were i changed my oil all the time to.
Re: Best $20.00 I have spent [Re: wildfish72] #90105
07/19/08 02:06 PM
07/19/08 02:06 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
$30.00 min you spend on an oil change
Re: Best $20.00 I have spent [Re: wildfish72] #90106
07/19/08 02:24 PM
07/19/08 02:24 PM
Upper Midwest
Upper Midwest
BS. I don't hire somebody to do it for me. I can still buy my oil and filters for well under 15 bucks a time.
Re: Best $20.00 I have spent [Re: MoparforLife] #90107
07/19/08 06:51 PM
07/19/08 06:51 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
ok lets say $3 dollars a qrt times 5 and then another $8 for the filter , what does that come out to , $23 , thats if all you need is 5 qrts my truck uses 7 qrts. so tell me you can do it for under $15 ,
Re: Best $20.00 I have spent [Re: wildfish72] #90108
07/19/08 07:00 PM
07/19/08 07:00 PM
Upper Midwest
Upper Midwest
Buy oil on sale under 10 bucks for 5 quarts (usually 1.79 qt.) and the same with filters. Filters are under 5 bucks on sale and not Fram. I don't care if you believe me or not I Have been servicing my own vehicles for nearly 50 years without a problem and can see no reason to change. It is your money to spend and if you feel better spending it that way that is fine with me. Just because it cost more don't mean it is any better.
PS: right now Mobil is on sale for 1.88 a quart.
Re: Best $20.00 I have spent [Re: MoparforLife] #90109
07/19/08 09:28 PM
07/19/08 09:28 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Yah, Ive been getting the Mobile oil at Costco and putting in a bottle of STP to fortify it. Should be no problem for my roller cam engine
Re: Best $20.00 I have spent [Re: dmerc] #90110
07/19/08 10:11 PM
07/19/08 10:11 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
BMW's SIA system ran off of driving habits, engine rpm, temperature, and fuel consumption to calculate its oil change intervals. The clock starts at 15,525 (off the top of my head i think thats what it is). From there depending on the items above it calculates the oils remaning life in it. In a perfect world you would get 15k out of your Mobil1. However also consider those engines run atleast 7 quarts of oil and do run very efficiently. So at 5,000 you're safe, but just for most that say 'German cars do it with that oil, my car can'...it depends on the cars driving conditions, varies car to car.
I run Mobil1 15w-50 in my Barracuda and Mobil1 5w-20 in my Ranger. Can be had for 'cheap' at wal-mart in 5qt jugs for ~$22. Figure I run 8,000 miles intervals with it in my truck (Cuda varies), it's more cost effective than regular engine oils.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Best $20.00 I have spent [Re: wildfish72] #90111
07/19/08 10:28 PM
07/19/08 10:28 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Bought a 5qt jug of Valvoline at Wal-mart tonight for $12 and a fram for the Pilot for $4, that's only $16 now tax would put me over but nothing was on sale. Mopar, Ford and AC Delco filters all under $5 and you can catch the 5qt Valvoline jugs for under $10 many times. Use good oil and change it regularly and you will never have an oil failure.
Careful, your character's showing!
Re: Best $20.00 I have spent [Re: mopar346] #90112
07/19/08 10:36 PM
07/19/08 10:36 PM
Upper Midwest
Upper Midwest
AMEN
Re: Best $20.00 I have spent [Re: MoparforLife] #90113
07/19/08 10:54 PM
07/19/08 10:54 PM
fresno ca
wildfish72 Offline
mopar addict
wildfish72  Offline
mopar addict
fresno ca
just open you mind old man and read,,,,,,, unless your that stuburn http://www.amsoil.com/storefront/atm.aspx
