RANCHO SHOCK PROBLEMS
#900775
01/10/11 08:58 AM
01/10/11 08:58 AM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
I have rancho 9 position rear shocks rs 9000 x part no rs99116. The shocks have 5/8" holes top and bottom and mopar size is 11/16". These are the part number calvert recomends. Has anyone had this problem.
Re: RANCHO SHOCK PROBLEMS
[Re: 572B1]
#900776
01/10/11 12:32 PM
01/10/11 12:32 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I believe I pressed out the metal sleeve and just ran the bushing on mine.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 572B1]
#900778
01/10/11 01:53 PM
01/10/11 01:53 PM
Posts: 5,894 Florida
Locomotion
I have 9114 (old 5-way) on my Dart Sport and they have the same bushing top & bottom. But you also have to look at the compressed and extended lengths for your particular application. The Rancho website has a part #/spec page that you can compare shocks. I dont have the direct page link handy. Rancho shocks
[Re: 572B1]
#900781
01/10/11 05:27 PM
01/10/11 05:27 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have the 99116's and they bolted on my Demon with no problem.
[Re: jbc426]
#900782
01/10/11 06:09 PM
01/10/11 06:09 PM
572B1
Brisbane Australia
I believe I pressed out the metal sleeve and just ran the bushing on mine. [/quote
My bushes are 5/8" and the metal sleeves are 1/2".
[Re: jbc426]
#900784
01/11/11 07:11 PM
01/11/11 07:11 PM
572B1
Brisbane Australia
If there's enough rubber to do so, remove the metal sleeve and ream the remaining rubber bushing up to the needed size.
We pay top dollar for made in the usa parts and nothing fits.
They can't even get a pair of shocks right.
I think next time, I order parts they will be chinese made.
What have i got to lose. rant over.
[Re: 572B1]
#900785
01/11/11 07:31 PM
01/11/11 07:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know its not right to have to fix a new part you spend good money on BUT you can push the inner sleeve out and press in a larger size(correct size) but you might to press one out of a old shock... I wouldnt just press out the inner and run the rubber on the bolt... you need that inner sleeve to butt against the cross member
[Re: MR_P_BODY]
#900786
01/11/11 07:40 PM
01/11/11 07:40 PM
572B1
Brisbane Australia
Mr P, The old shocks are 38 years old and the bushes are rubber, with no inner sleeves.
