driveshaft dent!!!!! #90012
07/17/08 08:58 PM
07/17/08 08:58 PM
alberta
Publicbottle Offline OP
alberta
I know driveshafts are balanced, but would a shallow dent about 1" diameter cause any vibrations????
Re: driveshaft dent!!!!! [Re: Publicbottle] #90013
07/17/08 09:19 PM
07/17/08 09:19 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Not for sure, but probable. If you have a dent and vibration I would suspect that's the problem.
Re: driveshaft dent!!!!! [Re: Publicbottle] #90014
07/17/08 09:47 PM
07/17/08 09:47 PM
the drieshaft is balanced with weights to set the center of gravity and center of weight to spin smoothly. if you dent the driveshaft or if you have extra stuff (mud, etc) on it, it will throw off the balance, and cause a vibration...
bottom line: yeah, the dent is probably causing your vibration.
i just replaced my driveshaft..check out denny's driveshafts in upstate NY...does a good job and prices are decent.
hope this helps.
PHM
Re: driveshaft dent!!!!! [Re: Publicbottle] #90015
07/18/08 12:48 AM
07/18/08 12:48 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Yes. Been there. What purpleheartmopar said.
