Initial/Total Timing #900088
01/09/11 10:29 AM
01/09/11 10:29 AM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
With an initial timing of 10 degrees BTDC and a total of 35 degrees. When does the # 1 cylinder actually fire? At 25 BTDC or 35 BTDC. Thanks!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Initial/Total Timing [Re: 36PLYM] #900089
01/09/11 10:36 AM
01/09/11 10:36 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Each cyl will fire at 10 degrees before top dead center, and up to 35 degrees before top dead center, depending on rpm.
Re: Initial/Total Timing [Re: 36PLYM] #900090
01/09/11 10:39 AM
01/09/11 10:39 AM
At or above the RPM where your springs are maxed out at if you are showing 35 that is 35 BTDC and is your total (checked w vac adv unhooked/plugged) Zero (TDC of the piston) on the balancer is just a reference point and initial fires 10 deg b 4 that and mech adv makes it fire an additional 25 b 4 (the 10 deg point) for 35 total. It's a linear amt (initial amt to total amt) from start to finish EDIT & vac adv will add to the # (circumference degrees on the dampener)up higher yet past the 35
Re: Initial/Total Timing [Re: RapidRobert] #900091
01/09/11 01:57 PM
01/09/11 01:57 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
I know this has been discussed a lot before but just for clarification- for total timing
1)Disconnect and plug vacuum advance
2)RPMs up to 3000
3)Timing gun set at 35
4)Timing mark on balancer should be at 0
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Initial/Total Timing [Re: 36PLYM] #900092
01/09/11 02:14 PM
01/09/11 02:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Only if your distributor has been recurved so that the advance is fully advanced at the specified RPM's. If it hasn't it will still be advancing past that RPM and may give you more than you planned on.
Re: Initial/Total Timing [Re: 36PLYM] #900093
01/09/11 02:15 PM
01/09/11 02:15 PM
No prob on any repeat, holler as much as you like. yes if the springs are maxed out at 3k (or earlier), then zero on the balancer/35 on the dialback. SB I'm assuming. If you want it spot on I would suggest setting (w vac adv disconnected/plugged), (1) initial (vac gauge method) then w that figure in hand (2) shorten the slots to get 35 total (SB) then (3) play w the springs staying just under the pinging point at WOT up thru the gears on your hottest/driest day then (4) reconnect the vac adv and start it's slope as fast as possible but again staying just under the pinging point at PART (high vacuum) throttle at an RPM high enough to where the springs (mech adv) are maxed out. CW w a 3/32" allen wrench makes it's curve start sooner (less in hg) and the total is fixed unless you file the notches longer (for more total) or shorten the notches w strips of feeler gauges epoxied on (for less total) or you can get a can w less adv (dist amt is stamped on the arm so double that #). The vac adv helps mileage and cleaner plugs and takes the most work to get it spot on as your dealing w 2 things, it's total it can add and when it starts advancing.
Re: Initial/Total Timing [Re: RapidRobert] #900094
01/09/11 02:21 PM
01/09/11 02:21 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Thanks guys! Time to go play!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Initial/Total Timing [Re: 36PLYM] #900095
01/09/11 02:54 PM
01/09/11 02:54 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
You didn't say what distributer you were using. IF it's a stock unit you'll want to remove the real heavy stock spring from the advance weights. Just leave the lighter spring alone and don't replace the other spring. Your timing should be all in by 22-2500rpm. Without removing that heavy stock spring it may not reach full advance until 4000+rpm. Dave
Re: Initial/Total Timing [Re: quickd100] #900096
01/09/11 06:43 PM
01/09/11 06:43 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Stock distributor with Pertronix, 71 318 with 340 J heads and Torker II intake, purple cam(don't know which one). Presently 625 Road Demon Jr. but have a 625 Road Demon ready to install. Sanderson headers, 518 auto, 2100 stall, 8 3/4 with 3:55 gears. Check out article Moparts-Members in Print "Back Burner Mopar"
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Initial/Total Timing [Re: 36PLYM] #900097
01/09/11 06:52 PM
01/09/11 06:52 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Keep in mind..
If he is using an MSD box, it fires 10 degrees before and after up to 3000 RPM..
Just my $0.02...
Re: Initial/Total Timing [Re: Sinitro] #900098
01/09/11 06:55 PM
01/09/11 06:55 PM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Keep in mind..
Just my $0.02...
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Initial/Total Timing [Re: Plum440] #900099
01/09/11 07:06 PM
01/09/11 07:06 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Pretty much stock ignition except for the Pertronix ignitor, coil and wires.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Initial/Total Timing [Re: 36PLYM] #900100
01/09/11 07:47 PM
01/09/11 07:47 PM
What QuickD100 said, the heavy spring w the long loop needs to go, alot of gain to b had. bottom line you pretty much want as much adv as it'll take w NO pinging at any point in time
Re: Initial/Total Timing [Re: quickd100] #900101
02/06/11 05:37 AM
02/06/11 05:37 AM
Central TX
roe Offline
roe  Offline
Central TX
Would this be a good mod on a daily driver? And how/where do you remove the spring from?
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Initial/Total Timing [Re: roe] #900102
02/06/11 11:52 PM
02/06/11 11:52 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
Here's a pic of the earlier style MP or Chrysler dist
Re: Initial/Total Timing [Re: six-barrel] #900103
02/07/11 01:32 AM
02/07/11 01:32 AM
Toss the one on the top side that's hidden in the pic
