1992 318 Magnum dual exhast question. #899688
01/08/11 05:29 PM
01/08/11 05:29 PM
waukon iowa
1hot68 Offline OP
1hot68  Offline OP
waukon iowa
What to do with the o2 sensor? The truck has true duals , no cat, o2 sensor only on the right side. and dynomax superturbos. The check engine light stays off . It runs decent. Im just curious if this is something that works or am I handicapping it by running it this way. Will the o2 sensor read close enuf just from the one side? Or should it have a y-pipe to work properly?
Thanks!
Re: 1992 318 Magnum dual exhast question. [Re: 1hot68] #899689
01/08/11 10:00 PM
01/08/11 10:00 PM
waukon iowa
1hot68 Offline OP
1hot68  Offline OP
waukon iowa
ttt
Re: 1992 318 Magnum dual exhast question. [Re: 1hot68] #899690
01/08/11 10:05 PM
01/08/11 10:05 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
Thanks!
You should put a Y pipe in it if it only has 1 o2 sensor unless theres some way to modify the computer so that you can have it read a second sensor.
Right now the bank that doesn't have an o2 sensor could be running super rich, super lean, misfiring, etc...and you would have no idea.
Re: 1992 318 Magnum dual exhast question. [Re: 1hot68] #899691
01/08/11 11:59 PM
01/08/11 11:59 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
99% of the time, one O2 (in either bank) will be fine. (this is also the way the factory 360/390HP SMPI crate conversion is setup up).
Rick
Re: 1992 318 Magnum dual exhast question. [Re: Rick_Ehrenberg] #899692
01/09/11 12:17 AM
01/09/11 12:17 AM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
Rick
Maybe I'm missing something but how would the computer know how rich or lean the other bank is running, especially on a smpi engine?
Re: 1992 318 Magnum dual exhast question. [Re: chache876] #899693
01/09/11 01:58 AM
01/09/11 01:58 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
It assumes nothing bad is happening to only one side and treats them both the same.
