moser vs strange ??????
#898846
01/07/11 06:50 PM
01/07/11 06:50 PM
Posts: 204 washington
AB&E
washington
okay I need help which one is more politically correct for 69 bee I am looking to replace my 8.75 with a 60 & do not know which one is more correct looking{ performance factor not so much an issue } thank you
Re: moser vs strange ??????
[Re: DoctorDiff]
#898849
01/08/11 02:19 AM
01/08/11 02:19 AM
AB&E
washington
I was told that moser was a better product?? a bit more $$$$$ strange s60 prslo5 shipped to wa state from summit $2015.90 decent price I thought still a lot of dough.
[Re: quick77rt ]
#898852
01/08/11 02:56 PM
01/08/11 02:56 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I would go Strange all the way much better piece IMO
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 68GTS383]
#898853
01/08/11 04:27 PM
01/08/11 04:27 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
"A good friend of mine is a Drag Racer and purchased a car with Strange axles.One of the axles broke and Strange would not stand behind it. He purchased Moser axles and the salesman told him that if he EVER broke one they would replace it for FREE!"
Sounds like your friend bought USED Strange axles.
SOME Moser axles have a 10 year warranty (not lifetime) and they will not cover any axle bought used. Here is a quote taken from Moser's website.
"This replacement policy only applies to the original purchaser and broken axles must be returned without alteration or repair, including welding, along with your proof of purchase, name, address, telephone number, and a description of the problem. This replacement policy applies only to asphalt drag race and typical street/strip applications. This replacement policy is not a warranty either expressed or implied."
[Re: 68GTS383]
#898856
01/08/11 07:27 PM
01/08/11 07:27 PM
DoctorDiff
Polson, MT
You said your friend bought a car with a pair of Strange axles alreadly installed (used, pre-owned or what ever else you want to call it). I pointed out that Moser, as well as Strange will replace a broken axle for the original purchaser ONLY. This is clearly stated by BOTH Strange AND Moser.
I'm a Strange Engineering dealer because I believe most of their products are a better value. The OP asked for opinions about Strange and Moser Dana 60 rears. Unlike Moser, Strange incorporated threaded carrier adjusters into their Dana 60 housing, rather than simply copying the original, flawed design. Why would anyone want to pay more for an outdated design that must be set up with a housing spreader? In addition, Strange uses OEM gears and all US made components in their S-60 assemblies.
[Re: 451Mopar]
#898860
01/09/11 12:58 PM
01/09/11 12:58 PM
Posts: 2,592 None
71rm23
None
[Re: justinp61]
#898862
01/09/11 01:07 PM
01/09/11 01:07 PM
Posts: 10,560 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would gladly trade my factory B-body housing for a new S-60 housing any day of the week The threaded adjusters are such a great addition to an already good part. I would go with Doctordiff if I were you Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
