Page 3 of 8 1 2 3 4 5 6 7 8
Re: 1000 hp guys or better [Re: moderncylinder] #897878
01/07/11 04:11 PM
01/07/11 04:11 PM
Houston, TX
rick55 Offline
rick55  Offline
Houston, TX
My son works for Steve Morris Engines. Yesterday he sent me a pic of a motor they just built for a customer. Mid 500" aluminum Indy block, fuel injected, F3r 139mm Procharger. On their engine dyno it put out over 2500hp.
Re: 1000 hp guys or better [Re: moderncylinder] #897879
01/07/11 04:52 PM
01/07/11 04:52 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
with 572-13 head you make a solid 950hp,, which would still be fast in a 2350lb car...
i know guys around here that made 1000 or a lil more then put it in their 3300lb car and run 8.80's,,, look at westcott's stick car making a lil under 1000 running 8.20's in a 3200lb car,,, those guys with over 1000 prob really had a lil over 900
Exactly!!!!!!
Re: 1000 hp guys or better [Re: rick55] #897880
01/07/11 06:33 PM
01/07/11 06:33 PM
Delray beach, Florida
P
Performance Only Offline
P
would love to know what kind of dyno that was. not many model dyno's that can handle that much power.
machine shop owner and engine builder
Re: 1000 hp guys or better [Re: Performance Only] #897881
01/07/11 06:45 PM
01/07/11 06:45 PM
detroit area
moderncylinder Offline
detroit area
most of the discussion is considering nat aspirated... with a pwer adder like a blower or nos,, power is almost unlimited
i think steve's "old" shop has a stuska dyno
Re: 1000 hp guys or better [Re: Performance Only] #897882
01/07/11 07:45 PM
01/07/11 07:45 PM
Houston, TX
rick55 Offline
rick55  Offline
Houston, TX
No one makes a dyno that can reliably stand up to 3500hp, so they have taken parts and pieces of different brands and fabricated many other parts and pieces to make a dyno that will handle 3500hp+. S basically they have a custom one off. Steve's motor dynoed just under 3500hp.
Re: 1000 hp guys or better [Re: rick55] #897883
01/07/11 07:51 PM
01/07/11 07:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what does it run at the track
Re: 1000 hp guys or better [Re: Quicktree] #897884
01/07/11 08:00 PM
01/07/11 08:00 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Re: 1000 hp guys or better [Re: Blusmbl] #897885
01/07/11 09:52 PM
01/07/11 09:52 PM
Houston, TX
rick55 Offline
rick55  Offline
Houston, TX
Thought you should know. Steve Morris is in no way affiliated with SMRE. Don't let anyone tell you otherwise.
Re: 1000 hp guys or better [Re: rick55] #897886
01/07/11 09:56 PM
01/07/11 09:56 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Steve Morris New Website
http://www.stevemorrisengines.com/
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: 1000 hp guys or better [Re: Quicktree] #897887
01/07/11 10:10 PM
01/07/11 10:10 PM
Houston, TX
rick55 Offline
rick55  Offline
Houston, TX
This is a video from Orlando earlier this winter. He had tire slippage all the way down the track, at 1000' mark he bounced off the wall at 190mph and still ran a 7.82.
http://www.youtube.com/watch?v=dxcKwcyQEq0&feature=player_embedded
Re: 1000 hp guys or better [Re: Get-X] #897888
01/08/11 09:57 AM
01/08/11 09:57 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
if you dont mind could/would you give a run down on the combo of parts used?? if you dont mind..looking at diff. set up and like to yes whats working for those that are doing it..thanks mike
car
weight
engine spec
trans
gear
tire
this is what my buddy is planned out so far not set in stone ye t...
dodge stratus tube chasiss car..being worked on now
world block
572 with 572heads poprted and polished
762 lift cam with jesal 1.6 rocker
intake ????
piston ?????
rod ?????
crank?????
trans glide
ford 9" rear coil over 4 link
looking for at lease a 1000hp or more for the combo on this build...
It takes a good engine to make 1000+. By that I mean 410+ cfm heads, 15:1+ comp., .800+ cam lift with serious valve springs. Should also consider using titanium intake valves. I'd use GRP rods around 7" and a 4.5 stroke Callies Magnum crank. I'd use the 440-3x intake and someones custom carb (Cubic, Books, ProSystems).
You need to speak to Best Machine for CNC porting on the 572-13, then you'll have the potential in those heads
BTW we aren't anywhere near 1000 hp (yet )
Re: 1000 hp guys or better [Re: Tig] #897889
01/08/11 02:28 PM
01/08/11 02:28 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Ok, I will play to..
I plan on making my 540 nitrous only, but will start out with a different cam and and run N/A first.
Block megablock, 4.50 bore
crank 4.25
alum. rods BME 7.15
Pistons CP flat top 14:1
Cam Intake lift with 1.8 ratio 0,792", Exh 0,774"
Intake dur 280° Exh. 289, LSA 112
Rockers T&D separate 1.8
Tit. intake valves 2.30 (+0,100 both int and ex)
Psi1248 tripple springs installed at 2.10"
B1 originals, fully ported by RAD racing
Single cast B1, ported
1050 AD, 9375 three circ.
I am hoping for at least 950 hp.
How much would a good 1250 carb help, like the new ultra hp ?
The cam is new and 10 years old, would it benefit with more ex dur. ?
Re: 1000 hp guys or better [Re: RT540] #897890
01/08/11 03:51 PM
01/08/11 03:51 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
Not sure if we will hit 1000 hp but that is the target and we should not be to far below
Aluminum world block 4.50 bore
crank 4.50
I beam rods 7.100
Pistons CP 15:1
Cam Intake lift with 0,806", Exh 0,798"
Intake dur 284° Exh. 292, LSA 112
2000 cfm throttle body
BS3 EFI methanol
Peterson 5 stage dry sump
25.1E Duster should end up 2450
5 speed lenco
Ford 4.30 rear
32 tall tire
76 Duster work in progress
Re: 1000 hp guys or better [Re: Edge] #897891
01/08/11 03:55 PM
01/08/11 03:55 PM
nc
E
earthmover Offline OP
E
nc
just asking why the i beams and not the h beams??? i thought the i beams would not stand up the this kinda power just asking i dont know...thanks mike nice by the way
Re: 1000 hp guys or better [Re: earthmover] #897892
01/08/11 04:24 PM
01/08/11 04:24 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I think the I beam vs H beam boils down to personal preference as there are advantages and disadvantages to both designs. Make sure you have a quality oiling system, bearings, pins, and hardware on the rods as these are the often the frequent sources of rod failures and not necessarily the design itself. imho
Re: 1000 hp guys or better [Re: Edge] #897893
01/08/11 04:27 PM
01/08/11 04:27 PM
nc
E
E
nc
thanks
Re: 1000 hp guys or better [Re: moderncylinder] #897894
01/08/11 04:33 PM
01/08/11 04:33 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Our customers that we actully built engines like this have run better than 8.80, but did have some car trouble like you . The MPH will show this better than ET, maybe you need a new engine builder? give us a call I know we can pick it up
Re: 1000 hp guys or better [Re: earthmover] #897895
01/08/11 05:06 PM
01/08/11 05:06 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
If I ever put a steel rod in a high hp aplication, it would be Oliver parabolic, which is a I-beam.
I am a firm belivier in alum. rods though.
Re: 1000 hp guys or better [Re: PETE@BESTMACHINE] #897896
01/08/11 05:43 PM
01/08/11 05:43 PM
detroit area
detroit area
pete youre a stroke,, get a life
Re: 1000 hp guys or better [Re: moderncylinder] #897897
01/08/11 06:54 PM
01/08/11 06:54 PM
SouthEast Michigan
P
P
SouthEast Michigan
People in glass houses ( ) shouldn't throw stones
