Re: 1000 hp guys or better
[Re: moderncylinder]
#897879
01/07/11 04:52 PM
01/07/11 04:52 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
with 572-13 head you make a solid 950hp,, which would still be fast in a 2350lb car...
i know guys around here that made 1000 or a lil more then put it in their 3300lb car and run 8.80's,,, look at westcott's stick car making a lil under 1000 running 8.20's in a 3200lb car,,, those guys with over 1000 prob really had a lil over 900
Exactly!!!!!!
[Re: Performance Only]
#897882
01/07/11 07:45 PM
01/07/11 07:45 PM
Posts: 193 Houston, TX
rick55
Houston, TX
would love to know what kind of dyno that was. not many model dyno's that can handle that much power.
No one makes a dyno that can reliably stand up to 3500hp, so they have taken parts and pieces of different brands and fabricated many other parts and pieces to make a dyno that will handle 3500hp+. S basically they have a custom one off. Steve's motor dynoed just under 3500hp.
[Re: rick55]
#897883
01/07/11 07:51 PM
01/07/11 07:51 PM
Quicktree
what does it run at the track
[Re: Get-X]
#897888
01/08/11 09:57 AM
01/08/11 09:57 AM
Posts: 2,933 A shed in England
Tig
A shed in England
if you dont mind could/would you give a run down on the combo of parts used?? if you dont mind..looking at diff. set up and like to yes whats working for those that are doing it..thanks mike
car weight engine spec trans gear tire
this is what my buddy is planned out so far not set in stone ye t...
dodge stratus tube chasiss car..being worked on now world block 572 with 572heads poprted and polished 762 lift cam with jesal 1.6 rocker intake ???? piston ????? rod ????? crank????? trans glide ford 9" rear coil over 4 link
looking for at lease a 1000hp or more for the combo on this build...
It takes a good engine to make 1000+. By that I mean 410+ cfm heads, 15:1+ comp., .800+ cam lift with serious valve springs. Should also consider using titanium intake valves. I'd use GRP rods around 7" and a 4.5 stroke Callies Magnum crank. I'd use the 440-3x intake and someones custom carb (Cubic, Books, ProSystems).
You need to speak to Best Machine for CNC porting on the 572-13, then you'll have the potential in those heads BTW we aren't anywhere near 1000 hp (yet )
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#897889
01/08/11 02:28 PM
01/08/11 02:28 PM
Posts: 1,664 North Sweden
RT540
North Sweden
Ok, I will play to..
I plan on making my 540 nitrous only, but will start out with a different cam and and run N/A first.
Block megablock, 4.50 bore crank 4.25 alum. rods BME 7.15 Pistons CP flat top 14:1 Cam Intake lift with 1.8 ratio 0,792", Exh 0,774" Intake dur 280° Exh. 289, LSA 112 Rockers T&D separate 1.8 Tit. intake valves 2.30 (+0,100 both int and ex) Psi1248 tripple springs installed at 2.10" B1 originals, fully ported by RAD racing Single cast B1, ported 1050 AD, 9375 three circ.
I am hoping for at least 950 hp. How much would a good 1250 carb help, like the new ultra hp ? The cam is new and 10 years old, would it benefit with more ex dur. ?
[Re: RT540]
#897890
01/08/11 03:51 PM
01/08/11 03:51 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Not sure if we will hit 1000 hp but that is the target and we should not be to far below
Aluminum world block 4.50 bore crank 4.50 I beam rods 7.100 Pistons CP 15:1 Cam Intake lift with 0,806", Exh 0,798" Intake dur 284° Exh. 292, LSA 112 B1 originals, fully ported Single cast B1, ported 2000 cfm throttle body BS3 EFI methanol Peterson 5 stage dry sump
25.1E Duster should end up 2450 5 speed lenco Ford 4.30 rear 32 tall tire
76 Duster
work in progress
[Re: earthmover]
#897892
01/08/11 04:24 PM
01/08/11 04:24 PM
Edge
Alberta Canada
I think the I beam vs H beam boils down to personal preference as there are advantages and disadvantages to both designs. Make sure you have a quality oiling system, bearings, pins, and hardware on the rods as these are the often the frequent sources of rod failures and not necessarily the design itself. imho
76 Duster
work in progress
[Re: earthmover]
#897895
01/08/11 05:06 PM
01/08/11 05:06 PM
RT540
North Sweden
just asking why the i beams and not the h beams??? i thought the i beams would not stand up the this kinda power just asking i dont know...thanks mike nice by the way
If I ever put a steel rod in a high hp aplication, it would be Oliver parabolic, which is a I-beam. I am a firm belivier in alum. rods though.
