I had My '67 440 bored .030 over,and had new Pistons,Rods,and Crank balanced,but didn't have
Harmonic balancer included.So I have three questions:Was Harmonic balancer manufactured and
balanced as an individual piece,and what effect
will using It"as is" have on My Engine??
And second: My torque Converter has a very thin
strip of weight spot welded onto It-was Torque
Converter manufactured and balanced as a separate
assembly?? There are two non-concentric shallow
holes drilled in Harmonic Balancer.Approx.2 inches
off centerline,7/16ths dia.,5/16ths deep,right next to each other.Do these holes balance the rotating mass of the harmonic balancer,or do they
serve as balancing the entire rotating assembly??
![](/ubbthreads/images/graemlins/shruggy.gif)
Eric @ Rickety Enterprises
